× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
What happened to smbplus addon
stevenestrada
Hello What happened to smblus? I upgraded the readynas os to 6.9.4, rebooted, logged on the gui, then hit the button to upgrade smbplus to 1.0.8 from 1.0.7. The addon disappreared off the screen with a vague warning the update didn't work. Then I go to the available addon page and smbplus isn't there.
Model: RN31400|ReadyNAS 300 Series 4-Bay
Message 1 of 12
bedlam1
Prodigy
Re: What happened to smbplus addon
It's on my GUI APPS available page using 6.9.4 and I just installed it as test.
Have you tried clearing your browser cache etc. or another browser?
Message 2 of 12
stevenestrada
Yeah I tried that So you can go to the available app page and see smbplus And don't get a usless error like this upgrading Sep 16, 2018 12:52:20 PM System: Cannot install application SMB Plus.
Message 3 of 12
bedlam1
Prodigy
No I didn't get those results (I also un-installed it succesfully)
Message 4 of 12
stevenestrada
If the app is still available and the upgrade bombed resulting in it disappearing off the installed and available pages, I guess I'll have to putty in and type something to get it back in. I tried.  Not a clue how to fix it
# apt install smbplus
Reading package lists... Done
Building dependency tree
Reading state information... Done
The following NEW packages will be installed:
  smbplus
0 upgraded, 1 newly installed, 0 to remove and 40 not upgraded.
1 not fully installed or removed.
Need to get 179 kB of archives.
After this operation, 580 kB of additional disk space will be used.
Get:1 http://apt.readynas.com/packages/readynasos 6.9.4/apps amd64 smbplus amd64 1.0.8 [179 kB]
Fetched 179 kB in 0s (7,998 kB/s)
debconf: delaying package configuration, since apt-utils is not installed
Selecting previously unselected package smbplus.
(Reading database ... 20207 files and directories currently installed.)
Preparing to unpack .../smbplus_1.0.8_amd64.deb ...
Unpacking smbplus (1.0.8) ...
Setting up rsyslog-mysql (8.4.2-1+deb8u2) ...
debconf: unable to initialize frontend: Dialog
debconf: (No usable dialog-like program is installed, so the dialog based frontend cannot be used. at /usr/share/perl5/Debconf/FrontEnd/Dialog.pm line 76.)
debconf: falling back to frontend: Readline
dbconfig-common: writing config to /etc/dbconfig-common/rsyslog-mysql.conf
dpkg: error processing package rsyslog-mysql (--configure):
 subprocess installed post-installation script returned error exit status 10
Setting up smbplus (1.0.8) ...
Errors were encountered while processing:
 rsyslog-mysql
E: Sub-process /usr/bin/dpkg returned an error code (1)
Message 5 of 12
Guru
Do you also have rsyslog installed?
Message 6 of 12
stevenestrada
rsyslog? I though I got rid of that last year it didn't work from day one is that the reason smbplus upgrade messed up? whats the fix
Message 7 of 12
Guru
Well, the error message points in that direction
... dpkg: error processing package rsyslog-mysql (--configure)
I'm not seeing any reference to that package in my own logs.  You could try uninstalling that from ssh.
Message 8 of 12
stevenestrada
That didn't work out too well.
I'm just going around in circles typing in commands
But smpplus 1.0.8 popped up on the installed apps gui with the picture gone.
And this error: System: Cannot uninstall application SMB Plus.
cifs access seems to be working fine
Seems I got a lot of cleaning up to do before the next os upgrade. Any clue how to fix this mess?
# apt-get remove rsyslog
The following packages were automatically installed and are no longer required:
  libmysqlclient18 mysql-common
Use 'apt autoremove' to remove them.
The following packages will be REMOVED:
  rsyslog rsyslog-mysql
0 upgraded, 0 newly installed, 2 to remove and 40 not upgraded.
After this operation, 2,109 kB disk space will be freed.
Do you want to continue? [Y/n] y
(Reading database ... 20278 files and directories currently installed.)
Removing rsyslog-mysql (8.4.2-1+deb8u2) ...
dpkg: error processing package rsyslog-mysql (--remove):
 subprocess installed pre-removal script returned error exit status 10
dbconfig-common: flushing administrative password
dpkg: error while cleaning up:
dpkg: rsyslog: dependency problems, but removing anyway as you requested:
 rsyslog-mysql depends on rsyslog (= 8.4.2-1+deb8u2).
Removing rsyslog (8.4.2-1+deb8u2) ...
 rsyslog-mysql
# apt-get --purge remove rsyslog
You might want to run 'apt-get -f install' to correct these:
The following packages have unmet dependencies:
 rsyslog-mysql : Depends: rsyslog (= 8.4.2-1+deb8u2) but it is not going to be installed
E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution).
# apt-get -f install
Correcting dependencies... Done
The following additional packages will be installed:
  rsyslog
Suggested packages:
  rsyslog-mongodb rsyslog-doc rsyslog-gnutls rsyslog-gssapi rsyslog-relp
  rsyslog
Need to get 0 B/546 kB of archives.
After this operation, 1,878 kB of additional disk space will be used.
Selecting previously unselected package rsyslog.
(Reading database ... 20232 files and directories currently installed.)
Preparing to unpack .../rsyslog_8.4.2-1+deb8u2_amd64.deb ...
Unpacking rsyslog (8.4.2-1+deb8u2) ...
Processing triggers for systemd (230-7~bpo8+2.netgear2) ...
Setting up rsyslog (8.4.2-1+deb8u2) ...
 rsyslog-mysql
Message 9 of 12
Guru
Did you try
apt-get --purge remove rsyslog-mysql
Unfortunately the best way to get a clean OS back is to do a factory reset and restore all the data from backup.
Message 10 of 12
stevenestrada
Yes I did.
# apt-get --purge remove rsyslog-mysql
  rsyslog-mysql*
0 upgraded, 0 newly installed, 1 to remove and 40 not upgraded.
After this operation, 231 kB disk space will be freed.
Do you want to continue? [Y/n] Y
dpkg: error processing package rsyslog-mysql (--purge):
 rsyslog-mysql
# apt-get --purge remove rsyslog-mysql -f
  rsyslog-mysql*
 rsyslog-mysql
# apt autoremove -f
0 upgraded, 0 newly installed, 0 to remove and 40 not upgraded.
After this operation, 0 B of additional disk space will be used.
 rsyslog-mysql
Don't they have a kb or something to step though cleaning things up?
If wiping put all my data and starting from scratch is the answer to fix one lousy addon that wont install/uninstall, this NAS belongs in the  garbage.
Message 11 of 12
Guru
Maybe try
# export DEBIAN_FRONTEND=noninteractive
# apt-get -yq --purge remove rsyslog-mysql
Paid support (my.netgear.com) can rebuild the OS from scratch w/o data loss, but there is no kb article on how to do that, and I don't know the details.
It would be useful for advanced users if it were documented, although I suspect there would also be less advanced users who would accidentally destroy their data when they attempted it.  It'd be better if there was a script or boot menu option to do this (perhaps part of the new safe mode?)
FWIW, in my view the issue here is that that rsyslog install scripts weren't correct to begin with, and the app shouldn't have listed as an available app by Netgear.
Message 12 of 12
Top Contributors
Discussion stats
  • 11 replies
  • 2427 views
  • 1 kudo
  • 3 in conversation
Announcements
