- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
What is a file "Versions"? 6.5.1
- Mark as New
- Bookmark
- Subscribe
- Permalink
When I right click a file name within a share, I am seeing "Versions" as a choice. What are they and where did they come from? When I look at the snapshots for that share, I do not see any connection between them and the versions.
Paul
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
The Versions will show you the different versions of the file that are retained in the Snapshot. If the version of the file is the same (duplicates) it will not display that version of the file. It should help users fine the different versions of the files based on the snapshot without having to look at a bunch of duplicate files that retain the same content.
The versioning/changing of the files are checked in BTRFS.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: What is a file "Versions"? 6.5.1
Hello paulinde,
Where do you see this? In admin page? Can you post a screenshot please?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello paulinde,
It must have something to do with Snapshots. Probably revisions of the file that you right clicked on.
- Mark as New
- Bookmark
- Subscribe
- Permalink
That was my first thought, however the numbers of snapshots do not equal the number of versions. ??
Cannot find anything in any docs that refer to this.
Paul
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello paulinde,
I'll check with others too while we wait if other moderators from Netgear have idea on this.
- Mark as New
- Bookmark
- Subscribe
- Permalink
The versions are history of file changes. The snapshots can be created every hour. The file can be changed never. Does not make a sense to keep versions of not changed file. So, number of snapshots should not be the same as number of file versions.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Exactly as sotrack explained 🙂
You can't compare snapshots with file versions. They are not the same thing.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks, but what controls the number of versions kept?
Paul
- Mark as New
- Bookmark
- Subscribe
- Permalink
It is still controlled by the snapshots themselves.
I have a file in a share.
- I snapshot the share daily.
- I change file only once over 3 days.
Now, I have 3 snapshots, but only two versions. Makes sense right? As old snapshots are prunned out over time, older versions of the file will also disappear.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
