× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
What is the maximum RAM & HD for Pioneer Pro, upgraded to OS6?
gclpc
Hi, all,
I am upgrading my Pioneer Pro to OS6 (hopefully). I see from the forums that upgrading the RAM is also advised. Could someone tell me the max RAM and HD sizes that can be used?
Thanks,
Greg
Model: RNDP6000|ReadyNAS Pro 6 Chassis only
Message 1 of 4
Accepted Solutions
Guru
Re: What is the maximum RAM & HD for Pioneer Pro, upgraded to OS6?
Max RAM is 8 GB.  Though that is expensive (4 GB ddr2 memory isn't common).  Adding 1 GB is enough to bring it up to what is in the RN424.  The 520x series (and the RN426) have 4 GB total.
OS-6 has no known limit on hard disk size.
Message 2 of 4
All Replies
Guru
Message 2 of 4
gclpc
Thank you
Message 3 of 4
Sandshark
Sensei
To be precise, 4GB low density (2Rx8), unregistered, non-ECC, DDR2 memory, which is what you would need, is uncommon.
High density (2Rx4, sometimes labled "AMD only") and server (ECC and/or registered) memory is a bit more common, but won't work.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 1229 views
  • 2 kudos
  • 3 in conversation
Announcements
