Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Will a Duo v1 (RAIDiator 4.1.8) backup to a 3 TB USB?
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-11-23
04:16 AM
2012-11-23
04:16 AM
Can it handle a 3 TB USB drive attached to it for use in Backup?
I am upgrading my Duo to 2 x 2TB XRAID setup and a 2 TB external USB drive may no longer be sufficient for backups ....
Message 1 of 5
Labels:
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-11-23
04:22 AM
2012-11-23
04:22 AM
Re: Will a Duo v1 (RAIDiator 4.1.8) backup to a 3 TB USB?
There is no support for disks larger in 2TB in capacity either internal or external.
Message 2 of 5
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-11-23
04:33 AM
2012-11-23
04:33 AM
You could connect the 3 TB USB drive to a PC, and backup over the network. The main disadvantage is that the PC would need to be turned on when the backup is scheduled (and left on until it completes).
If you are sticking with X-Raid, your current USB drive should be ok (unless you are storing multiple backups on the same drive). After expansion, the duo's volume should be slightly smaller than the external drive size.
Message 3 of 5
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-11-23
05:39 AM
2012-11-23
05:39 AM
I'm OK with one backup set on my USB drive.
But I have the backups set to "Full backup once every week". If I select "Remove the contents of the backup destination before a full backup is performed." then there will be a short period (well, with the backup speeds I see, more like a day and a half!) when I won't have any backup (before the current full backup is completed).
If there was an option to 'Replace files on destination when doing full backup", that would be better, IMO.
Message 4 of 5
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-11-23
06:32 AM
2012-11-23
06:32 AM
You could try shifting to rsync (http://www.rnasguide.com/2010/09/23/rsy ... -usb-disk/).
Message 5 of 5
