× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
X-RAID vertical expansion incomplete
Retired_Member
Not applicable
ReadyNAS 314 running OS 6.4.0
Was previously running with 4x1TB drives. As we came close to filling that up, ordered 4x2TB drives for vertical expansion.
Replaced the disk in bay 1, waited for resync to complete, no problems.
Replaced the disk in bay 2, waited for resync to complete, no problems. After that it began a second lengthy operation (I can't remember the exact verbiage used, but I'm fairly confident that this was expanding the capacity to make use of the two newer disks). No problems.
Replaced the disk in bay 3, waited for resync to complete, no problems. Waited for expansion to complete, no problems.
Replaced the disk in bay 4, waited for resync to complete, no problems. I did not immediately notice that the final expansion did not take place.
This unit has SSH enabled, so when I noticed that the capacity wasn't what I expected (it reports 4.45 TB capacity instead of the expected 5.24 TB), I poked around a bit and found this:
root@netgear:~# btrfs filesystem show /data
Label: '5e276904:data'  uuid: 7e35ca18-0d2e-45f7-aa31-a82747bea137
        Total devices 2 FS bytes used 2.61TiB
        devid    1 size 2.71TiB used 2.63TiB path /dev/md127
        devid    2 size 1.82TiB used 171.00GiB path /dev/md126
btrfs-progs v4.1.2
root@netgear:~# mdadm --detail /dev/md127
/dev/md127:
        Version : 1.2
  Creation Time : Tue Jul  9 03:32:40 2002
     Raid Level : raid5
     Array Size : 2915731968 (2780.66 GiB 2985.71 GB)
  Used Dev Size : 971910656 (926.89 GiB 995.24 GB)
   Raid Devices : 4
  Total Devices : 4
    Persistence : Superblock is persistent
    Update Time : Tue Sep  6 17:50:49 2016
          State : clean
 Active Devices : 4
Working Devices : 4
 Failed Devices : 0
  Spare Devices : 0
         Layout : left-symmetric
     Chunk Size : 64K
           Name : 5e276904:data-0  (local to host 5e276904)
           UUID : e33eecc1:f9ec98cf:0bae86e1:28333094
         Events : 3594
    Number   Major   Minor   RaidDevice State
       4       8        3        0      active sync   /dev/sda3
       5       8       19        1      active sync   /dev/sdb3
       6       8       35        2      active sync   /dev/sdc3
       7       8       51        3      active sync   /dev/sdd3
root@netgear:~# mdadm --detail /dev/md126
/dev/md126:
        Version : 1.2
  Creation Time : Tue Aug  9 17:01:44 2016
     Raid Level : raid5
     Array Size : 1953245824 (1862.76 GiB 2000.12 GB)
  Used Dev Size : 976622912 (931.38 GiB 1000.06 GB)
   Raid Devices : 3
  Total Devices : 4
          State : clean
 Active Devices : 3
Working Devices : 4
 Failed Devices : 0
  Spare Devices : 1
     Chunk Size : 64K
           Name : 5e276904:data-1  (local to host 5e276904)
           UUID : df0953ba:a63f8097:563d7345:af6846f6
         Events : 3031
       0       8        4        0      active sync   /dev/sda4
       1       8       20        1      active sync   /dev/sdb4
       2       8       36        2      active sync   /dev/sdc4
       3       8       52        -      spare   /dev/sdd4
root@netgear:~# mdadm --examine /dev/sdd4
/dev/sdd4:
          Magic : a92b4efc
        Version : 1.2
    Feature Map : 0x0
     Array UUID : df0953ba:a63f8097:563d7345:af6846f6
     Raid Level : raid5
   Raid Devices : 3
 Avail Dev Size : 1953245896 (931.38 GiB 1000.06 GB)
  Used Dev Size : 1953245824 (931.38 GiB 1000.06 GB)
    Data Offset : 262144 sectors
   Super Offset : 8 sectors
   Unused Space : before=262056 sectors, after=72 sectors
          State : clean
    Device UUID : 3de39043:50f0af6e:cbcdc324:337612b0
    Update Time : Fri Aug 12 01:47:27 2016
  Bad Block Log : 512 entries available at offset 72 sectors
       Checksum : 1e90ec50 - correct
         Events : 3031
     Chunk Size : 64K
   Device Role : spare
   Array State : AAA ('A' == active, '.' == missing, 'R' == replacing)
It looks like the device kept the original RAID array as-is with the ~3TB storage capactiy in the first 1TB of each drive, built a second RAID 5 array using the next 1TB of each drive, and then used BTRFS features to join them into a single filesystem (which is fine). What I don't understand is why the second RAID array (/dev/md126) is treating the top 1TB of the fourth disk (/dev/sdd4) as a 'spare' rather than an active disk. All four new disks are identical Western Digital Reds.
We have good backups and so in principle I could just wipe the array and start over, however this array is actively used in a business and the associated downtime is not particularly appealing, especially since I'm not often physically on-site with the unit.
Model: RN31400|ReadyNAS 300 Series 4- Bay
Message 1 of 9
Accepted Solutions
mdgm-ntgr
NETGEAR Employee Retired
Re: X-RAID vertical expansion incomplete
Yes, but you do want to check the disks are healthy, partitions are the correct size etc. before doing that.
Doing it yourself is at your own risk.
Message 7 of 9
All Replies
mdgm-ntgr
That's easily fixed.
Btw 6.4.0 is old firmware. Once the problem is fixed you may wish to update the firmware.
Message 2 of 9
omicron_persei8
Luminary
You could try to simply reboot the NAS. Otherwise, I would fail, remove then add sdd4 from/to md126. If you're not comfortable with fixing the RAID yourself, you could try to contact NETGEAR Support.
Message 3 of 9
omicron_persei8
Luminary
Actually, you might just need to grow the number of raid devices of md126 from 3 to 4.
Message 4 of 9
mdgm-ntgr
Assuming everything is fine, yes. Once the RAID is expanded the volume should automatically expand.
Message 5 of 9
Retired_Member
Not applicable
Am I correct that this would be accomplished simply by running
mdadm --grow /dev/md126 --raid-devices=4
from SSH (assuming the system is in all other ways healthy)? Or are there any special considerations introduced by ReadyNAS or BTRFS?
--- EDIT ---
Nevermind, just saw your PM, mdgm. Thanks for the info, I'll give it a shot after some additional checks.
Message 6 of 9
mdgm-ntgr
Message 7 of 9
Retired_Member
Not applicable
Just wanted to say, everything seemed to work out well. Various health checks such as smartctl (and others I no longer recall) came back clean, and, after running the suggest mdadm command the volume expansion began as expected. It completed without issue.
Thanks for your assistance.
Message 8 of 9
JennC
Hello Retired_Member,
We are glad that it works now.
We encourage you to post any suggestion, comments or questions you have that you feel like posting. We appreciate your contribution.
Message 9 of 9
Top Contributors
Discussion stats
  • 8 replies
  • 3772 views
  • 0 kudos
  • 4 in conversation
Announcements
