Dashu's avatar
Dashu
apt-get update problem
Would love to install git-scm on my Ultra 4 NAS but currently apt-get update is stopping me from doing this.
The error I need to overcome is:
NAS:~# apt-get update
Get:1 http://archive.debian.org etch Release.gpg
Get:2 http://www.readynas.com 4.2.18/ Release.gpg
Get:3 http://archive.debian.org etch Release
Get:4 http://www.readynas.com 4.2.18/ Release
Ign http://www.readynas.com 4.2.18/ Release
Get:5 http://www.readynas.com 4.2.18/ Packages
Ign http://archive.debian.org etch Release
Get:6 http://archive.debian.org etch/main Packages
99% [5 Packages gzip 0]
gzip: stdin: not in gzip format
Err http://www.readynas.com 4.2.18/ Packages
Sub-process gzip returned an error code (1)
99% [6 Packages gzip 0]
Err http://archive.debian.org etch/main Packages
Fetched 21.6kB in 20s (1077B/s)
Failed to fetch http://www.readynas.com/packages/4.2.18/Packages.gz Sub-process gzip returned an error code (1)
Failed to fetch http://archive.debian.org/debian/dists/etch/main/binary-i386/Packages.gz Sub-process gzip returned an error code (1)
Reading package lists... Done
W: GPG error: http://www.readynas.com 4.2.18/ Release: The following signatures were invalid: NODATA 1 NODATA 2
W: GPG error: http://archive.debian.org etch Release: The following signatures were invalid: NODATA 1 NODATA 2
W: Couldn't stat source package list http://www.readynas.com 4.2.18/ Packages (/var/lib/apt/lists/www.readynas.com_packages_4.2.18_Packages) - stat (2 No such file or directory)
W: Couldn't stat source package list http://archive.debian.org etch/main Packages (/var/lib/apt/lists/archive.debian.org_debian_dists_etch_main_binary-i386_Packages) - stat (2 No such file or directory)
W: You may want to run apt-get update to correct these problems
E: Some index files failed to download, they have been ignored, or old ones used instead.
My sources.list;
deb http://www.readynas.com/packages 4.2.18/
deb http://archive.debian.org/debian etch main
Thanks for any help
  • Maybe you just need to try again. Some of the debian mirrors had some problems lately. Other than that you may want to check the free space on the OS partition of your ReadyNAS. If there's not enough room left for unpacking the indizes, you'd see the errors you're getting.
    -Stefan
  • How would one go about viewing free space on OS partition?
    Feels weird with the "No such file or directory" error, the file is clearly there.
    Has been like this for two weeks now.
    Thanks for you help!
  • Filesystem Size Used Avail Use% Mounted on
    /dev/md0 4.0G 431M 3.4G 12% /
    tmpfs 16K 0 16K 0% /USB
    /dev/c/c 1.9T 977G 870G 53% /c
    /c/home 1.9T 977G 870G 53% /home/ftp/homes
    /c/media 1.9T 977G 870G 53% /home/ftp/media
  • I guess you tried downloading one of the files in question manually to check whether they actually exist or not. If I'm correct there, did you try downloading from your desktop computer or from the ReadyNAS? Chances are your ReadyNAS got some wrong DNS information or can't get to the hosts with the files for some other reason.
    For a simple check, what happens if you do a
    wget http://archive.debian.org
    when on an SSH shell on the ReadyNAS?
    -Stefan
  • Thanks Stefan!
    Your reply got me thinking and now I feel a bit shamed.
    The way my network is set up, the NAS haven't got connection to the internet :)
    Hmm need to solve how to get the 3g usb modem working on the nas first.
    Thanks for your help!
ProSupport for Business
