× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
balance stuck at 0%, what can I do?
Dewdman42
Virtuoso
I recently enabled scheduled Balancing on my readynas OS6.  It started the balance job last night at midnight as specified.  However, today I can't login via SSH and can't mount the SMB shares and all I can do is get to the frontview screen, which all seems to work, but it says currently balancing at 0% and basically everything such as timemachine has stopped working..aside from frontview..
what can I do to get this working?  I already tried to restart it from frontview, which I'm not sure it even did or not.
Model: RNDP200U|ReadyNAS Ultra 2 Plus Chassis only
Message 1 of 9
Guru
Re: balance stuck at 0%, what can I do?
Generally speaking, the longer a balance takes to run, the more it is needed.
What firmware are you running?
You can check the status with ssh using
# btrfs balance status -v /data
(or substituting your volume name if that is different).
You can also manually cancel it using
# btrfs balance cancel /data
Another option is to pause it during the day, and resume it at night (letting it finish off-hours)
# btrfs balance pause /data
# btrfs balance resume /data
I'd also suggest taking a look at disk health, as that could explain the very slow speed.
# smartctl -x /dev/sda
# smartctl -x /dev/sdb
Adding the -x gives you information on disk errors that often doesn't show up in the SMART stats.
Message 2 of 9
Dewdman42
Virtuoso
I can’t do any of those things because ssh won’t work for me now. I get the “last logged in” message then it hangs there and never gives me a prompt.
Front view seems to work and says balancing is 0% done.
OS6, latest one
Message 3 of 9
Guru
Frontview runs at a lower priority than ssh, so it's odd that it is responding when ssh isn't.
Can you get the logs with RAIDar?
One option is to try a reboot, and see if you can get in with ssh quickly.
@Dewdman42 wrote:
OS6, latest one
Meaning 6.10.0
Message 4 of 9
Dewdman42
Virtuoso
Will try those things today. The whole device is mostly being used only as a time machine and smb backup device. I might just do a hard factory reset and make sure to set up scheduled balancing from the beginning.
It has been using a jbod raid, is there any reason to suspect that would cause a problem with balancing?
Message 5 of 9
Guru
No, not that I can think of.
I was wondering about a disk issue though, so if you do decide to go with a reset you might want to test them.
Message 6 of 9
Dewdman42
Virtuoso
Well the good news is that over night it completed...  all works fine now.  just took a long time.  no idea why it needed to turn off ssh and SMB while it was running, but maybe now its on a weekly schedule it won't take so long next time
Message 7 of 9
Guru
I run it every three months (my schedule for all the maintenance tests).
It ran a couple weeks ago on my RN526x (18 TB volume, about 14 TB of data), and took about 20 minutes.
Message 8 of 9
Sandshark
Sensei
When one of my eSATA expansion chasses (one EDA500 and one other brand) do a balance or scrub, I have seen the readynasd task go to 100% CPU use in TOP, and then HTTP and SMB access stops.  I can only see it via SSH because i already have the session open when it happens.  And that's on an RN516, so I can imagine what would happen on the lower-powered Ultra.  When all is going right, the various kworker and such processes don't even take half the CPU throughput.
When it doe shappen. I can typically pause a balance, let readynasd "calm down:", and then re-start the balance.  But there is no pausing a scrub.   I suspect that the readynasd process gets some kind of time-out in accessing the volume and then goes into a state it should not be in.  I figured it was because of the eSATA port expander in the external chasses creating a bottleneck, but maybe it can happen in other cases as well.
You may want to start an SSH sesson running TOP and then manually do a scrub to see if something similar is happening to you.
Message 9 of 9
Top Contributors
Discussion stats
  • 8 replies
  • 1342 views
  • 0 kudos
  • 3 in conversation
Announcements
