- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
cannot get over 100 mpbs while backing up
- Mark as New
- Bookmark
- Subscribe
- Permalink
with my WD mycloud id get over 500 mbps over ethernet. i've been using readynas for 2 weeks now to do many different backups and just notice not a single one went over 100 mbps. i must be missing a setting or something?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: cannot get over 100 mpbs while backing up
Is the ethernet LED showing amber (fast ethernet) or green (gigabit)?
Have you tried swapping the cables used by the two NAS? Maybe also try swapping the ports used in the router/switch.
You should be getting 100 MB/s for large file transfers.
- Mark as New
- Bookmark
- Subscribe
- Permalink
my laptop is hooked up directly to the router and i see no lights on either end of the cable (archer c7 router) ac 1750
i have a cable going from the router to a switch and from that switch one cable goes to the mycloud and other cable goes to NAS
both lights on the switch are green
when i go to network settings and ethernet status on the laptop it says 1 gbps. if i disconnect , the wifi is less than 200 mbps
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ok. Was the 100 mbps speed measured over wifi?
Can you try testing the speed with NasTester? http://www.808.dk/?code-csharp-nas-performance
Please test with the ethernet connected to the laptop.
- Mark as New
- Bookmark
- Subscribe
- Permalink
i cannot test ready nas as i dont know the path. its not a letter and entering the IP doesnt work
when i said under 200 on wifi that means the wifi status under network status. task manager never gets above 100 on wifi nor ethernet
i just found on the readynas admin screen under network it says eth0 bandwidth 100
under that is eth1 with 1gbps and its greyed out
- Mark as New
- Bookmark
- Subscribe
- Permalink
Average (R): 11.56 MB/sec
i was able to run that test on mycloud
Average (W): 11.79 MB/sec
i dont know if this means anything or not but i have this
Qualcomm Atheros AR8151 PCI-E Gigabit Ethernet Controller (NDIS 6.30
and under device manager properties advanced theres a setting speed and duplex and its set to auto negotiation. BUT the highest number on the drop down menu is 100 mbps. however ive seen 500 in acronis with old backups. so something is amiss. its the latest driver too.
- Mark as New
- Bookmark
- Subscribe
- Permalink
jackpot. i figured it out. the switch did indeed have green on the front but then i noticed amber on the NAS
i connected the router right to the NAS and i'm getting over 800 mbps!
it's a 10/100 switch i got free after rebate from newegg and now i know why 🙂
i thought cat 5e could do gigabit?. it was 6e running from router to switch then i had 5e to mycloud and readynas
- Mark as New
- Bookmark
- Subscribe
- Permalink
Cat 5e can carry gigabit ethernet. But a 10/100 switch can't, so all connections to that switch will negotiate fast ethernet (100 mbps).
Gigabit switches are inexpensive (5 port unmanaged switches have street prices < $25 USD) - so if you need a switch you should just get a new one.
