Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
difficulty accessing readynas with raidar
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-08-10
09:57 AM
2011-08-10
09:57 AM
Greetings,
I have two Readynas solutions, a pro 6 and an ultra 6, both systems are on the same subnet as the user machines. Systems accessing the files include windows 7 and Mac OSX 10.6.8. The Ultra has 4.2.18 installed and the pro has .17. I am using firefox 5.0.1 to access the Frontview from the Macs. The switch being used is a Cisco SG 200-08, a managed Gig-E switch w/ port aggregation capabilities. I had aggregated the Pro and the Mac Pro nics but once the problems stated went back to single nics to isolate the problems. All systems are on the same Class C network.
My problem. I just stood up the Pro and there seems to be some kind of confusion on the network. I see the shares (sharing NFS, AFP and CIF - no music or streaming). I changed the names of the shares so at least I do not have two 'media' shares on the network. I see the shares and when I try to access them the access hangs or causes the OS systems to crash. I cannot access the systems from raidar, the browser asks for my username/psswd and then just spins. Firefox simply states that it is waiting on the ULTRA to respond. I have since turned off the PRO, thinking there was a conflict. I did an OS re-install on the ULTRA and that temporarily fixed the problem.
Any ideas?
Thanks
Erick
Any ideas?
Thanks
Erick
Message 1 of 3
Labels:
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-08-10
11:21 AM
2011-08-10
11:21 AM
Re: difficulty accessing readynas with raidar
ok tried other browsers and tried going directly to the device http://myIP/admin and no dice. odd as I can get to it from my OSX laptop, has the same OSX version.
./e
./e
Message 2 of 3
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-08-11
06:03 AM
2011-08-11
06:03 AM
I think I may have found the issue and it deals with the ReadyNAS's ability to deal w/ jumbo frames or potentially the inability. Using the same gear as mentioned above, I changed the interface on the Mac Pro to an MTU of 1518 and BAM right into the web interface. Now the reason why I could access via the laptop makes sense as I was coming across via 802.11. Going to test it around a bit to see if I should set the MTU to a lower amount versus the 9000 listed in ReadyNAS GUI, set it on the MAC. I figure I leave the switch alone, allow it to process up to 9000 but throttle the Mac to a lower amount...see what happens.
I checked the switch 1gig w/ an MTU of 9000, flow control enabled. maybe its a flow control issue? one step at a time.
./e
./e
Message 3 of 3
