Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
expanding readynas pro 6 past 16tb
- Mark as New
- Bookmark
- Subscribe
- Permalink
2014-11-28
04:37 AM
2014-11-28
04:37 AM
I have just upgraded the disks in my readynas to 4x4tb and 2x3tb. Once I put the disks in I did a factory reset and it started to build a volume of 13.2tb ie it was seeing each disk as 3tb. Once it finished and I rebooted it it said it had found extra space and was expanding. Almost immediately it said it had failed.
Have I been trapped into the 16th expansion problem - ie if you are going beyond 16tb you must put in equally sized disks otherwise it wont expand into the unequal ones?
I did upgrade radiator to latest version before I started.
Stephen
Stephen
Message 1 of 2
Labels:
- Mark as New
- Bookmark
- Subscribe
- Permalink
2014-11-28
04:41 AM
2014-11-28
04:41 AM
Re: expanding readynas pro 6 past 16tb
Yes.
Some users decide to run OS6 as that doesn't have this expansion limit, but our support team does not support running OS6 on the legacy units.
Message 2 of 2
