Orbi WiFi 7 RBE973
Reply
force power on after lost power on Duo V2
paul45
Hi, as the subject suggests... I'm looking for a way to force my Duo V2 to power back on after lost power (I get frequent power outages). The NAS is a media server in a home that I am at infrequently. I didn't see anything in the device's menu for this so I'm at a loss and looking for suggestions. I'm surprised if this is not possible as every time it loses power it's just a brick, very frustrating.
Message 1 of 5
tony359
Apprentice
Re: force power on after lost power on Duo V2
You can enable the WOL, even though you need to properly shut down the unit for the WOL to work (it goes in a sort of standby where the NIC is still listening).
I hope you have an UPS for your installation and the UPS could trigger a proper shutdown when the power does not come back straight away - and then you can WOL the unit.
If you don't have a UPS, your ReadyNAS will surely become a brick at some point 🙂
Message 2 of 5
paul45
Thanks for the reply. Could you recommend a UPS?
Message 3 of 5
mdgm-ntgr
NETGEAR Employee Retired
Most APC UPS units that have a USB port (note must be a USB port, serial to USB cables are incompatible) should work fine.
Message 4 of 5
paul45
Thank you again..very helpful
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 1665 views
  • 0 kudos
  • 3 in conversation
Announcements
