Reply
Highlighted
Follower
has only 2 healthy drives, no display, and fan running
Looking for some assistance with my Readynas NV+. The issue started with Drive 4 flashing green indicator. Assuming that the drive was on the way out, or already doomed, I purchased a USB backup drive the unit booted up OK but I was unable to power it down using the power button, it appeared to be frozen. I then removed the plug so I could try and reboot the device and now all it does is show healthy indicators (green) for drive 1 & 3, no display, fan continues to run at full noise, cannot see the device on the network.
I am really starting to panic now as I have not been able to backup my extremely important data and cannot even get the device to boot. PLEASE HELP
I am dubious about doing anything else at present but curious as to whether I can swap drives between bays for diagnosing whether its failed drives or the NAS itself as it was being difficult. Will/can this dig my hole deeper?
I am running 4 x 2T Seagate Barracuda drives
Model: RND4000v2|ReadyNAS NV+ v2 Chassis only
Message 1 of 3
Highlighted
NETGEAR Moderator
Re: has only 2 healthy drives, no display, and fan running
Hi Kiles,
Welcome to the Community!
I would not recommend swapping the drives between bays because it will just make the issue worse.
It would be best for you to contact NETGEAR support (paid support) so they can check what caused the issue and also, assist you in recovering the data.
JohnCM_S
NETGEAR Community Team
Message 2 of 3
Highlighted
NETGEAR Moderator
Hi Kiles,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as a solution so others can be confident in benefiting from the solution.
The NETGEAR community looks forward to hearing from you and being a helpful resource in the future!
JohnCM_S
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 362 views
  • 0 kudos
  • 2 in conversation
Announcements
