× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
health changed from Redundant to Degraded
HariSeldon0FE
 Hey i saw this in my log today waht does it mean(its a readynas 104, the diskless version i bought my own HDDs)
Mon Feb 15 2016 1:47:49
Disk: Disk Model:WDC WD40EFRX-68WT0N0 Serial:WD-WCC4E1490316 was removed from Channel 4 of the head unit.
Mon Feb 15 2016 1:47:19
Disk: Disk Model:WDC WD40EFRX-68WT0N0 Serial:WD-WCC4E1490316 was added to Channel 4 of the head unit.
Mon Feb 15 2016 1:45:32
Volume: Pending shutdown cancelled due to resync operation on volume Misc.
Mon Feb 15 2016 1:45:22
Volume: Resyncing started for Volume Misc.
Mon Feb 15 2016 1:45:02
Disk: System will be shut down in 30 minutes because of disk failure.
Mon Feb 15 2016 1:42:59
Volume: Volume Misc health changed from Redundant to Degraded.
under Volumes it says volume is degraded and it is currently resynching, under preformance the dot next to the disk is yellow and when i hover over it says resync
thanks in advance for all help
Message 1 of 10
mdgm-ntgr
NETGEAR Employee Retired
Re: health changed from Redundant to Degraded
Does that disk have any SMART errors?
Can you send me your logs (see the Sending Logs link in my sig)?
Message 2 of 10
HariSeldon0FE
How do i check the smart status?
when i go to http://IP.OF.NAS/dbbroker i get
nternal Server Error
The server encountered an internal error or misconfiguration and was unable to complete your request.
Please contact the server administrator, admin@localhost and inform them of the time the error occurred, and anything you might have done that may have caused the error.
More information about this error may be available in the server error log.
Apache/2.2.31 (Debian) Server at IP.OF.NAS Port 80
I am running firmware 6.4.1
Message 3 of 10
Guru
Normally you'd use https://IP.OF.NAS/admin
but you shouldn't see that error with your URL (at least I don't with 6.4.2).
You can also try downloading the logs with RAIDar 6
Message 4 of 10
HariSeldon0FE
Message 5 of 10
HariSeldon0FE
well its still resynching so far so good i think
does the onedrive link with the log work for you guys?
Message 6 of 10
mdgm-ntgr
Those SMART stats look fine.
Once the resync that is in progress completes I would suggest that you update to 6.4.2 and see if you run into the issue again.
You may also wish to disable the anti-virus service as there is a known performance issue with that at the moment.
Message 7 of 10
HariSeldon0FE
is it okay to enable antivirus again?
Message 8 of 10
Guru
You either need to install the hotfix or upgrade to 6.5
Message 9 of 10
HariSeldon0FE
cool i have already upgraded to 6.5.0
Message 10 of 10
Top Contributors
Discussion stats
  • 9 replies
  • 3102 views
  • 0 kudos
  • 3 in conversation
Announcements
