× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
how to downgrade my NAS firmware from 6.10.10
makkistyle
Hi,
  I'm not a developer geek and don't know how to use the codes or ssh
is there easy way to downgrade the OS .. I searched and found option
in admin page to do so .. but it requires me to upload the file for it and I don't have the old OS ..
the issue is that I can't update my Plex app anymore ..
Message 1 of 19
Accepted Solutions
Sandshark
Sensei
Re: how to downgrade my NAS firmware from 6.10.10
Indeed, sources.list.d seems to be a place where apps can put their own sources.list and not worry that an OS update will change them.  On my VM with Docker installed, it's sources list is there, called docker-cli-rnapp.list.  Don't do anything with them.  You need to put apt.conf and the updated sources.list in /etc/apt.
Message 12 of 19
All Replies
Guru
You can get it from here:
Best to extract it from the zip file before you upload.
the issue is that I can't update my Plex app anymore ...
Unfortunately, download back to 6.10.9 likely won't be enough.  I believe you will find that you will need to update the two files in this thread:
You can download them from post 37 in the thread.
If you enable SSH on the NAS, you can then install them using WinSCP on the PC.  If you set the protocol to SFTP, you should get access to the /etc folder from that GUI.  This approach doesn't require knowledge of SSH commands.
Message 2 of 19
makkistyle
Hi,
Thanks for your quick reply .. I manage to downgrade the OS only
the next step I was not able to connect to the server as SFTP
and wasn't able to use admin control panel ..
what the correct address to connect via SFTP app :
I use Mac app :
and in CP I activate the FTP but there was not option for SFTP:
what do you mean by GUI ?
Message 3 of 19
makkistyle
~Here are the connections options I have in the app :
Message 4 of 19
Guru
You need to enable ssh in the NAS in order to get sftp to work.  Make sure you enable password authentication when you do that.
Also, log in as "root", not as "admin".  But still use the NAS admin password.
Message 5 of 19
makkistyle
I loged in
but the root is empty
am i missing something ?
Message 6 of 19
Guru
I'm not a Mac user, but I am confused what the settings for "Root URL", "Local Path" and "Remote Path" are about.
The normal path for the NAS would be /
Message 7 of 19
makkistyle
I manage to access :
can you just guide me for last step
I just have to replace the file I downloaded  ( sources.list ) over NAS version ?
what about the file ( apt.conf ) where it should go ?
Message 8 of 19
makkistyle
there is a file ( apt.conf.d )
and this what shows inside :
Message 9 of 19
Guru
I replied to your other post
Message 10 of 19
Sandshark
Sensei
So apt.conf.d is a directory, not a file.  I don't run OS6.10.10, though maybe I do need to put it on a virtual machine to investigate.  Is this the new home of sources.list, or is there still one at the level above?  What are the contents of that apt.conf?
I'm thinking that Netgear may have created apt.conf.d as a safe place to put mods to sources.list and apt.conf that don't get over-written by an OS update.
Message 11 of 19
Sandshark
Sensei
Message 12 of 19
makkistyle
I would like to thank both  StephenB and Sandshark
for their solutions and effort they put in this forum your contributions are tremendous
I solved the upload issue and I manage to upload the Plex app
I hope there is a button in setting to turn off the update OS for good and for now on
it must not be updated for good .because it keeps popping up when you log in to admin page .
Regards
Message 13 of 19
adinx
Hello friends,
Thanks for finding a solution to the problem.
Unfortunately for me, i have followed the instructions but still get an error message - "apps operation failed" when I try to update my Plex.
I downgraded to 6.10.9, renamed the apt.conf.d to apt.conf.d.orig, renamed the  sources.list that is already in the folder to sources.list.orig, added the mods to the /etc/apt folder and tried updating my Plex.
Please is there any step I am missing?
@Sandshark @StephenB any help will truly be appreciated.
Message 14 of 19
Guru
Maybe try installing the deb file from ssh?  That would give a more informative error.
You could also look in apt-install.log and apt-history.log in the log zip file, the error details should also be in there.
Message 15 of 19
Sandshark
Sensei
Nothing in the instructions tell you to do anything with apt.conf.dapt.conf probably doesn't exist on your NAS prior to this.  After you make the changes, you also need to do an apt-get update.
Message 16 of 19
adinx
Apologies for not responding earlier. Realised my volume was read only so been backing up my content over the last few days. Did a factory reset so currently rebuilding the volume. Will retry after its all done.
Message 17 of 19
adinx
Update:
After restoring to factory settings due to the issue that was keeping my volume in read only, I downgraded to 6.10.9 and it allowed me install Plex from the featured apps section. Was also able to update Plex with a .deb file without having to use the mods. Thanks again for your help.
Message 18 of 19
Guru
The mods are needed whenever the deb file requires a new library.  Plex doesn't at the moment, but future updates might.
Message 19 of 19
Top Contributors
Discussion stats
  • 18 replies
  • 4623 views
  • 4 kudos
  • 4 in conversation
Announcements
