× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
http://home.bott.ca/webserver/
interested
Tutor
Does anybody know what is mit boot.ca server ???
It is out of reach.
Message 1 of 10
super_poussin
Virtuoso
Re: http://home.bott.ca/webserver/
Perhaps David shut it down 😞
Send him a PM, I'm sure he will answer
Message 2 of 10
InTheShires
Tutor
Working for me, although a bit on the slow side perhaps?
Message 3 of 10
Guru
It was down for a while due to an ISP problem, but is back on line now.
Message 4 of 10
dbott67
Guide
Still here... as Stephen B noted, I had some major ISP problems. Everything should be running normally as of June 4th or so.
Message 5 of 10
kullyrai
Tutor
Gives a database error with the following at the moment:
Error establishing a database connection
Message 6 of 10
dbott67
Guide
Thanks... fixed now.
I was having this really strange networking issue last night where I couldn't access one of my remote servers from any of my ReadyNAS devices [destination network unreachable], however, all of my other devices could access it perfectly fine. After a couple hours of troubleshooting [disabling bonding, jumbo frames, rebooting, etc] I noticed that the ReadyNAS Remote service (specifically the LeafNetworks adpater) has a network ID & subnet mask of 5.169.x.y/255.0.0.0 that was conflicting with my remote server (which has an IP of 5.79.x.y).
Anyhow, I've disabled the LeafNetworks adapter, restarted mysqld and everything is now working properly.
Message 7 of 10
Guru
Your remote server was assigned a real [public] 5.x.x.x address?
I've posted on this before, the LeafNetworks adapter shouldn't be using these addresses. Netgear has had 3 years to avoid a foreseeable problem [5.x.x.x. were assigned by IANA in 2010, before that they were reserved for "experimental" use).
Message 8 of 10
dbott67
Guide
Yes. I believe it's hosted by Leaseweb.com.
Message 9 of 10
Guru
That makes sense, as the 5.x.x.x addresses went to RIPE, which handles IPv4 addresses for Europe, the Middle East, and part of Asia.
Message 10 of 10
Top Contributors
Discussion stats
  • 9 replies
  • 1895 views
  • 0 kudos
  • 6 in conversation
Announcements
