× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
iSCSI strange behavior with random write (utorrent)
WingDog
Guide
Hello,
I'm using RND6 Pro with E7300/4Gb/6*2Tb WD Black (x-raid/raid5 mode) and windows 8.1 x64 as client.
all NICs are Gigabit. One NIC at client and one NIC at RND.
Later I had FW 4.2.27 and one LUN (500Gb) connected to client as utorrent downloads target.
I was able to download 2-3 torrents with ISO files (linux distro or MS distro) at the same time, before "disk overloaded 100%" at utorrent.
Now I've updated to FW 6.3.5 (nothing else were changed!), created Thick LUN, conncted it to client and start utorrent.
Even with one torrent file (two ISOs) I got "disk overloaded 100"
Need any advice about this problem.
P.S. Please don't advice to use smb/cifs - I need iSCSI disk.
Message 1 of 7
mdgm-ntgr
NETGEAR Employee Retired
Re: iSCSI strange behavior with random write (utorrent)
Is the LUN thin/thick?
Did you enable bit-rot protection?
What about snapshots?
What about sync writes?
Message 2 of 7
WingDog
Guide
Hello, mdgm.
LUN is Thick.
no, bit-rot protection is off (default setting)
no snapshot (disabled)
sync write is allowed (default setting)
Message 3 of 7
mdgm-ntgr
Can you disable sync writes and see what difference this makes?
Do you recall which firmware you were running when you created the LUN?
Message 4 of 7
WingDog
Guide
mdgm
I think this is one cause
https://community.netgear.com/t5/ReadyNAS-in-Business/MPIO-slow-speed/td-p/964959/highlight/false/pa...
with Disabled sync writes it's a very-very little faster.
FW R4toR6_latest-beta.bin from your post at previous forum.
Message 5 of 7
mdgm-ntgr
If your speed when not using MPIO is a lot faster then that would suggest the problem is with how you are using that.
Message 6 of 7
WingDog
Guide
there is no difference, MPIO or single path.
now I believe that there is one root cause.
check MPIO thread.
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 5534 views
  • 0 kudos
  • 2 in conversation
Announcements
