× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
kernel bug ReadyNASOS 6.10.1 screen massage __extent_writepsge_io+1d3
jukkaforss
Tutor
Hi,
My Readynas hit kernel bug, it running latests code 6.10.1.
Dmesg output after it happened. I needed to power cycle to get it rebooted.
[1108355.142034] ------------[ cut here ]------------
[1108355.146933] kernel BUG at fs/btrfs/extent_io.c:3400!
[1108355.152192] invalid opcode: 0000 [#1] SMP
[1108355.301048] Modules linked in: vpd(PO)
[1108355.305129] CPU: 0 PID: 4578 Comm: nfsd Tainted: P           O    4.4.178.x86_64.1 #1
[1108355.313300] Hardware name: NETGEAR ReadyNAS 314/To be filled by O.E.M., BIOS 4.6.5 11/05/2013
[1108355.322211] task: ffff8800c3362a00 ti: ffff8800c34d8000 task.ti: ffff8800c34d8000
[1108355.330033] RIP: 0010:[<ffffffff882b5f5a>]  [<ffffffff882b5f5a>] __extent_writepage_io+0x1d3/0x398
[1108355.339383] RSP: 0018:ffff8800c34db8d8  EFLAGS: 00010206
[1108355.344991] RAX: ffff880108549870 RBX: ffffea0000d2ba80 RCX: 0000007d07005000
[1108355.352456] RDX: 0000007d07005000 RSI: 0000007d06ffd000 RDI: 0000000000000000
[1108355.359908] RBP: ffff8800c34db978 R08: 0000000000001000 R09: 0000000000000001
[1108355.367396] R10: ffffea0000f0bd40 R11: ffff8800ad6b5488 R12: 0000007d07014000
[1108355.374860] R13: ffff8800c34dbb58 R14: 0000000000000000 R15: 0000000000001000
[1108355.382324] FS:  0000000000000000(0000) GS:ffff88011fc00000(0000) knlGS:0000000000000000
[1108355.390783] CS:  0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[1108355.396857] CR2: 00007f2ad2a30000 CR3: 00000000c72e9000 CR4: 00000000000006f0
[1108355.404345] Stack:
[1108355.406591]  ffff8800c6f31ab0 ffff8800c6f31900 000000fa00000000 0000000000001000
[1108355.414442]  0000007d06ffd000 0000000000000000 ffff8800c34dbaf8 ffff8800c6f31ab0
[1108355.422276]  ffff8800c6f31900 0000000000000000 ffff8800c34db988 0000007d07014fff
[1108355.430093] Call Trace:
[1108355.432782]  [<ffffffff882b7579>] __extent_writepage+0x176/0x1db
[1108355.439119]  [<ffffffff882b7885>] extent_write_cache_pages.isra.10.constprop.26+0x2a7/0x374
[1108355.447881]  [<ffffffff8807d2ff>] ? ttwu_do_activate.constprop.23+0x57/0x5c
[1108355.455197]  [<ffffffff882b7d3f>] extent_writepages+0x47/0x58
[1108355.461274]  [<ffffffff8829bfab>] ? uncompress_inline+0x148/0x148
[1108355.467720]  [<ffffffff8829bc08>] btrfs_writepages+0x23/0x25
[1108355.473764]  [<ffffffff880e68b3>] do_writepages+0x1e/0x28
[1108355.479483]  [<ffffffff880de30e>] __filemap_fdatawrite_range+0xb2/0xca
[1108355.486349]  [<ffffffff880de3a3>] filemap_fdatawrite_range+0xe/0x10
[1108355.492969]  [<ffffffff882ae6bb>] btrfs_fdatawrite_range+0x1b/0x41
[1108355.499477]  [<ffffffff882ae71c>] start_ordered_ops+0x3b/0x5a
[1108355.505561]  [<ffffffff882ae794>] btrfs_sync_file+0x59/0x2da
[1108355.511550]  [<ffffffff883168b3>] ? security_file_open+0x79/0x80
[1108355.517877]  [<ffffffff881416d2>] vfs_fsync_range+0x86/0x95
[1108355.523780]  [<ffffffff881fb87e>] nfsd_vfs_write+0x219/0x265
[1108355.529758]  [<ffffffff881fd531>] nfsd_write+0xa6/0xc6
[1108355.535202]  [<ffffffff88202552>] nfsd3_proc_write+0x90/0xab
[1108355.541175]  [<ffffffff881f7ec3>] nfsd_dispatch+0xcd/0x189
[1108355.546991]  [<ffffffff888c825b>] svc_process+0x582/0x6b6
[1108355.552711]  [<ffffffff881f7924>] ? nfsd_destroy+0x57/0x57
[1108355.558516]  [<ffffffff881f7a19>] nfsd+0xf5/0x147
[1108355.563527]  [<ffffffff88078c4a>] kthread+0xdc/0xe4
[1108355.568693]  [<ffffffff88078b6e>] ? kthread_worker_fn+0x129/0x129
[1108355.575098]  [<ffffffff888e476f>] ret_from_fork+0x3f/0x80
[1108355.580807]  [<ffffffff88078b6e>] ? kthread_worker_fn+0x129/0x129
[1108355.587229] Code: 48 3d 01 f0 ff ff 44 0f 43 d0 45 89 d6 e9 c3 01 00 00 48 8b 70 18 48 89 f1 48 03 48 20 48 89 75 80 48 89 ca 72 07 49 39 cc 72 06 <0f> 0b 48 83 ca ff 4c 29 e2 48 8b b5 78 ff ff ff 48 8b 78 70 4c
[1108355.608271] RIP  [<ffffffff882b5f5a>] __extent_writepage_io+0x1d3/0x398
[1108355.615266]  RSP <ffff8800c34db8d8>
[1108355.619704] ---[ end trace 6b6431a8ef19cb1c ]---
Model: RN31400|ReadyNAS 300 Series 4- Bay (Diskless)
Message 1 of 10
Accepted Solutions
Guru
Re: kernel bug ReadyNASOS 6.10.1 screen massage __extent_writepsge_io+1d3
Shrinking this one down ...
@jukkaforss wrote:
sdb part 1
root@readynas:~# smartctl -x /dev/sdb
ID# ATTRIBUTE_NAME          FLAGS    VALUE WORST THRESH FAIL RAW_VALUE
  1 Raw_Read_Error_Rate     POSR-K   200   200   051    -    159
  9 Power_On_Hours          -O--CK   028   028   000    -    52621
Error 9 [8] occurred at disk power-on lifetime: 50321 hours (2096 days + 17 hours)
Error: UNC at LBA = 0x12fdf7710 = 5098141456
Error 8 [7] occurred at disk power-on lifetime: 50321 hours (2096 days + 17 hours)
Error: WP at LBA = 0x12fdf7710 = 5098141456
Error 7 [6] occurred at disk power-on lifetime: 41988 hours (1749 days + 12 hours)
Error: UNC at LBA = 0xcf083840 = 3473422400
Error 6 [5] occurred at disk power-on lifetime: 41988 hours (1749 days + 12 hours)
Error: WP at LBA = 0xcf083840 = 3473422400
Error 5 [4] occurred at disk power-on lifetime: 38618 hours (1609 days + 2 hours)
Error: UNC at LBA = 0xe824a0c0 = 3894714560
Error 4 [3] occurred at disk power-on lifetime: 38618 hours (1609 days + 2 hours)
Error: WP at LBA = 0xe824a0b8 = 3894714552
Error 3 [2] occurred at disk power-on lifetime: 38618 hours (1609 days + 2 hours)
Error: UNC at LBA = 0xe824a0b8 = 3894714552
Error 2 [1] occurred at disk power-on lifetime: 38615 hours (1608 days + 23 hours)
Error: WP at LBA = 0x11616d4b8 = 4665562296
I saw a similar pattern on one of my WD60EFRX drives a while ago, and when I tested it with Lifeguard it failed.   Though a second disk with the same pattern passed Lifeguard.  So I recommend testing this disk (and perhaps replace it even if it does pass).
The most recent logged error was about 2000 hours ago (~ 3 months), so that particular error didn't cause the most recent crash.  But I'm thinking that this disk likely triggered it anyway.
FWIW, I haven't seen any explanation of how to decode the raw read error rate.  But it is quite a bit higher on this drive than your other ones.
Message 10 of 10
All Replies
Guru
I'd look in kernel.log and system.log for disk errors and btrfs errors.
Message 2 of 10
jukkaforss
Tutor
Kernel log has same messages, but I couldn't found anything from disk_info and btrfs logs.
No ATA errors or any other problems with disks.
Message 3 of 10
Guru
If ssh is enabled then smartctl -x might also give a clue.
Message 4 of 10
jukkaforss
Tutor
sda
root@readynas:~# smartctl -x /dev/sda
smartctl 6.6 2017-11-05 r4594 [x86_64-linux-4.4.178.x86_64.1] (local build)
Copyright (C) 2002-17, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF INFORMATION SECTION ===
Model Family:     Western Digital Red
Device Model:     WDC WD30EFRX-68AX9N0
Serial Number:    WD-WMC1T3093795
LU WWN Device Id: 5 0014ee 6adf64469
Firmware Version: 80.00A80
User Capacity:    3,000,592,982,016 bytes [3.00 TB]
Sector Sizes:     512 bytes logical, 4096 bytes physical
Device is:        In smartctl database [for details use: -P show]
ATA Version is:   ACS-2 (minor revision not indicated)
SATA Version is:  SATA 3.0, 6.0 Gb/s (current: 3.0 Gb/s)
Local Time is:    Fri Jun 28 11:01:44 2019 EEST
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
AAM feature is:   Unavailable
APM feature is:   Unavailable
Rd look-ahead is: Enabled
Write cache is:   Enabled
DSN feature is:   Unavailable
ATA Security is:  Disabled, frozen [SEC2]
Wt Cache Reorder: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status:  (0x00)	Offline data collection activity
					was never started.
					Auto Offline Data Collection: Disabled.
Self-test execution status:      (   0)	The previous self-test routine completed
					without error or no self-test has ever
					been run.
Total time to complete Offline
data collection: 		(40020) seconds.
capabilities: 			 (0x7b) SMART execute Offline immediate.
					Auto Offline data collection on/off support.
					Suspend Offline collection upon new
					command.
					Offline surface scan supported.
					Self-test supported.
					Conveyance Self-test supported.
					Selective Self-test supported.
SMART capabilities:            (0x0003)	Saves SMART data before entering
					power-saving mode.
					Supports SMART auto save timer.
Error logging capability:        (0x01)	Error logging supported.
					General Purpose Logging supported.
Short self-test routine
recommended polling time: 	 (   2) minutes.
Extended self-test routine
recommended polling time: 	 ( 401) minutes.
Conveyance self-test routine
recommended polling time: 	 (   5) minutes.
SCT capabilities: 	       (0x70bd)	SCT Status supported.
					SCT Error Recovery Control supported.
					SCT Feature Control supported.
					SCT Data Table supported.
SMART Attributes Data Structure revision number: 16
Vendor Specific SMART Attributes with Thresholds:
  1 Raw_Read_Error_Rate     POSR-K   200   200   051    -    19
  3 Spin_Up_Time            POS--K   210   179   021    -    4475
  4 Start_Stop_Count        -O--CK   100   100   000    -    135
  5 Reallocated_Sector_Ct   PO--CK   200   200   140    -    0
  7 Seek_Error_Rate         -OSR-K   200   200   000    -    0
  9 Power_On_Hours          -O--CK   028   028   000    -    52622
 10 Spin_Retry_Count        -O--CK   100   100   000    -    0
 11 Calibration_Retry_Count -O--CK   100   100   000    -    0
 12 Power_Cycle_Count       -O--CK   100   100   000    -    135
192 Power-Off_Retract_Count -O--CK   200   200   000    -    100
193 Load_Cycle_Count        -O--CK   200   200   000    -    34
194 Temperature_Celsius     -O---K   105   103   000    -    45
196 Reallocated_Event_Count -O--CK   200   200   000    -    0
197 Current_Pending_Sector  -O--CK   200   200   000    -    0
198 Offline_Uncorrectable   ----CK   100   253   000    -    0
199 UDMA_CRC_Error_Count    -O--CK   200   200   000    -    0
200 Multi_Zone_Error_Rate   ---R--   200   200   000    -    0
                            ||||||_ K auto-keep
                            |||||__ C event count
                            ||||___ R error rate
                            |||____ S speed/performance
                            ||_____ O updated online
                            |______ P prefailure warning
General Purpose Log Directory Version 1
SMART           Log Directory Version 1 [multi-sector log support]
Address    Access  R/W   Size  Description
0x00       GPL,SL  R/O      1  Log Directory
0x01           SL  R/O      1  Summary SMART error log
0x02           SL  R/O      5  Comprehensive SMART error log
0x03       GPL     R/O      6  Ext. Comprehensive SMART error log
0x06           SL  R/O      1  SMART self-test log
0x07       GPL     R/O      1  Extended self-test log
0x09           SL  R/W      1  Selective self-test log
0x10       GPL     R/O      1  NCQ Command Error log
0x11       GPL     R/O      1  SATA Phy Event Counters log
0x21       GPL     R/O      1  Write stream error log
0x22       GPL     R/O      1  Read stream error log
0x80-0x9f  GPL,SL  R/W     16  Host vendor specific log
0xa0-0xa7  GPL,SL  VS      16  Device vendor specific log
0xa8-0xb7  GPL,SL  VS       1  Device vendor specific log
0xbd       GPL,SL  VS       1  Device vendor specific log
0xc0       GPL,SL  VS       1  Device vendor specific log
0xc1       GPL     VS      93  Device vendor specific log
0xe0       GPL,SL  R/W      1  SCT Command/Status
0xe1       GPL,SL  R/W      1  SCT Data Transfer
SMART Extended Comprehensive Error Log Version: 1 (6 sectors)
No Errors Logged
SMART Extended Self-test Log Version: 1 (1 sectors)
Num  Test_Description    Status                  Remaining  LifeTime(hours)  LBA_of_first_error
# 1  Extended offline    Completed without error       00%     51571         -
# 2  Extended offline    Completed without error       00%     49451         -
# 3  Extended offline    Completed without error       00%     47246         -
# 4  Extended offline    Completed without error       00%     45038         -
# 5  Extended offline    Completed without error       00%     42831         -
# 6  Extended offline    Completed without error       00%     40690         -
# 7  Extended offline    Completed without error       00%     38490         -
# 8  Extended offline    Completed without error       00%     36297         -
# 9  Extended offline    Completed without error       00%     31941         -
#10  Extended offline    Completed without error       00%     29743         -
#11  Extended offline    Completed without error       00%     27530         -
#12  Extended offline    Completed without error       00%     25340         -
#13  Extended offline    Completed without error       00%     23167         -
#14  Extended offline    Completed without error       00%     20964         -
#15  Extended offline    Completed without error       00%     18761         -
#16  Extended offline    Completed without error       00%     16586         -
#17  Extended offline    Completed without error       00%     14453         -
#18  Extended offline    Completed without error       00%     13048         -
SMART Selective self-test log data structure revision number 1
 SPAN  MIN_LBA  MAX_LBA  CURRENT_TEST_STATUS
    1        0        0  Not_testing
    2        0        0  Not_testing
    3        0        0  Not_testing
    4        0        0  Not_testing
    5        0        0  Not_testing
Selective self-test flags (0x0):
  After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
SCT Status Version:                  3
SCT Version (vendor specific):       258 (0x0102)
SCT Support Level:                   1
Device State:                        Active (0)
Current Temperature:                    45 Celsius
Power Cycle Min/Max Temperature:     43/46 Celsius
Lifetime    Min/Max Temperature:      2/47 Celsius
Under/Over Temperature Limit Count:   0/0
Vendor specific:
01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
SCT Temperature History Version:     2
Temperature Sampling Period:         1 minute
Temperature Logging Interval:        1 minute
Min/Max recommended Temperature:      0/60 Celsius
Min/Max Temperature Limit:           -41/85 Celsius
Temperature History Size (Index):    478 (303)
Index    Estimated Time   Temperature Celsius
 304    2019-06-28 03:04    46  ***************************
 ...    ..(  5 skipped).    ..  ***************************
 310    2019-06-28 03:10    46  ***************************
 311    2019-06-28 03:11    45  **************************
 312    2019-06-28 03:12    45  **************************
 313    2019-06-28 03:13    45  **************************
 314    2019-06-28 03:14    44  *************************
 ...    ..( 65 skipped).    ..  *************************
 380    2019-06-28 04:20    44  *************************
 381    2019-06-28 04:21    43  ************************
 ...    ..(  2 skipped).    ..  ************************
 384    2019-06-28 04:24    43  ************************
 385    2019-06-28 04:25    44  *************************
 ...    ..(236 skipped).    ..  *************************
 144    2019-06-28 08:22    44  *************************
 145    2019-06-28 08:23    45  **************************
 ...    ..( 23 skipped).    ..  **************************
 169    2019-06-28 08:47    45  **************************
 170    2019-06-28 08:48    46  ***************************
 ...    ..(  7 skipped).    ..  ***************************
 178    2019-06-28 08:56    46  ***************************
 179    2019-06-28 08:57    45  **************************
 ...    ..( 60 skipped).    ..  **************************
 240    2019-06-28 09:58    45  **************************
 241    2019-06-28 09:59    44  *************************
 ...    ..( 15 skipped).    ..  *************************
 257    2019-06-28 10:15    44  *************************
 258    2019-06-28 10:16    45  **************************
 ...    ..( 18 skipped).    ..  **************************
 277    2019-06-28 10:35    45  **************************
 278    2019-06-28 10:36    46  ***************************
 ...    ..( 24 skipped).    ..  ***************************
 303    2019-06-28 11:01    46  ***************************
SCT Error Recovery Control:
           Read:     70 (7.0 seconds)
          Write:     70 (7.0 seconds)
Device Statistics (GP/SMART Log 0x04) not supported
Pending Defects log (GP Log 0x0c) not supported
SATA Phy Event Counters (GP Log 0x11)
ID      Size     Value  Description
0x0001  2            0  Command failed due to ICRC error
0x0002  2            0  R_ERR response for data FIS
0x0003  2            0  R_ERR response for device-to-host data FIS
0x0004  2            0  R_ERR response for host-to-device data FIS
0x0005  2            0  R_ERR response for non-data FIS
0x0006  2            0  R_ERR response for device-to-host non-data FIS
0x0007  2            0  R_ERR response for host-to-device non-data FIS
0x0008  2            0  Device-to-host non-data FIS retries
0x0009  2            4  Transition from drive PhyRdy to drive PhyNRdy
0x000a  2            4  Device-to-host register FISes sent due to a COMRESET
0x000b  2            0  CRC errors within host-to-device FIS
0x000f  2            0  R_ERR response for host-to-device data FIS, CRC
0x0012  2            0  R_ERR response for host-to-device non-data FIS, CRC
0x8000  4        82376  Vendor specific
Message 5 of 10
jukkaforss
Tutor
sdc
root@readynas:~# smartctl -x /dev/sdc
Serial Number:    WD-WMC1T3536142
LU WWN Device Id: 5 0014ee 603508514
Local Time is:    Fri Jun 28 11:02:55 2019 EEST
					was never started.
					been run.
data collection: 		(42420) seconds.
					command.
					power-saving mode.
recommended polling time: 	 ( 425) minutes.
  1 Raw_Read_Error_Rate     POSR-K   200   200   051    -    5
  3 Spin_Up_Time            POS--K   211   183   021    -    4450
  4 Start_Stop_Count        -O--CK   100   100   000    -    133
  9 Power_On_Hours          -O--CK   029   029   000    -    52517
 12 Power_Cycle_Count       -O--CK   100   100   000    -    133
192 Power-Off_Retract_Count -O--CK   200   200   000    -    98
194 Temperature_Celsius     -O---K   101   099   000    -    49
                            ||||||_ K auto-keep
                            |||||__ C event count
                            ||||___ R error rate
No Errors Logged
# 1  Extended offline    Completed without error       00%     51468         -
# 2  Extended offline    Completed without error       00%     49348         -
# 3  Extended offline    Completed without error       00%     47142         -
# 4  Extended offline    Completed without error       00%     44933         -
# 5  Extended offline    Completed without error       00%     42735         -
# 6  Extended offline    Completed without error       00%     40586         -
# 7  Extended offline    Completed without error       00%     38385         -
# 8  Extended offline    Completed without error       00%     36197         -
# 9  Extended offline    Completed without error       00%     31836         -
#10  Extended offline    Completed without error       00%     29639         -
#11  Extended offline    Completed without error       00%     27427         -
#12  Extended offline    Completed without error       00%     25240         -
#13  Extended offline    Completed without error       00%     23064         -
#14  Extended offline    Completed without error       00%     20861         -
#15  Extended offline    Completed without error       00%     18661         -
#16  Extended offline    Completed without error       00%     14348         -
#17  Extended offline    Completed without error       00%     12944         -
#18  Extended offline    Completed without error       00%     12775         -
    1        0        0  Not_testing
    2        0        0  Not_testing
    3        0        0  Not_testing
    4        0        0  Not_testing
    5        0        0  Not_testing
Current Temperature:                    49 Celsius
Power Cycle Min/Max Temperature:     47/50 Celsius
Lifetime    Min/Max Temperature:      2/51 Celsius
Vendor specific:
Temperature History Size (Index):    478 (189)
 190    2019-06-28 03:05    49  ******************************
 ...    ..(  8 skipped).    ..  ******************************
 199    2019-06-28 03:14    49  ******************************
 200    2019-06-28 03:15    48  *****************************
 ...    ..( 62 skipped).    ..  *****************************
 263    2019-06-28 04:18    48  *****************************
 264    2019-06-28 04:19    47  ****************************
 273    2019-06-28 04:28    47  ****************************
 274    2019-06-28 04:29    48  *****************************
 ...    ..( 24 skipped).    ..  *****************************
 299    2019-06-28 04:54    48  *****************************
 300    2019-06-28 04:55    47  ****************************
 ...    ..(  9 skipped).    ..  ****************************
 310    2019-06-28 05:05    47  ****************************
 311    2019-06-28 05:06    48  *****************************
 ...    ..( 79 skipped).    ..  *****************************
 391    2019-06-28 06:26    48  *****************************
 392    2019-06-28 06:27    47  ****************************
 ...    ..( 15 skipped).    ..  ****************************
 408    2019-06-28 06:43    47  ****************************
 409    2019-06-28 06:44    48  *****************************
 ...    ..( 74 skipped).    ..  *****************************
   6    2019-06-28 07:59    48  *****************************
   7    2019-06-28 08:00    47  ****************************
 ...    ..(  5 skipped).    ..  ****************************
  13    2019-06-28 08:06    47  ****************************
  14    2019-06-28 08:07    48  *****************************
 ...    ..( 17 skipped).    ..  *****************************
  32    2019-06-28 08:25    48  *****************************
  33    2019-06-28 08:26    49  ******************************
 ...    ..( 22 skipped).    ..  ******************************
  56    2019-06-28 08:49    49  ******************************
  57    2019-06-28 08:50    50  *******************************
 ...    ..(  3 skipped).    ..  *******************************
  61    2019-06-28 08:54    50  *******************************
  62    2019-06-28 08:55    49  ******************************
 ...    ..( 63 skipped).    ..  ******************************
 126    2019-06-28 09:59    49  ******************************
 127    2019-06-28 10:00    48  *****************************
 ...    ..( 23 skipped).    ..  *****************************
 151    2019-06-28 10:24    48  *****************************
 152    2019-06-28 10:25    49  ******************************
 ...    ..( 16 skipped).    ..  ******************************
 169    2019-06-28 10:42    49  ******************************
 170    2019-06-28 10:43    50  *******************************
 ...    ..( 18 skipped).    ..  *******************************
 189    2019-06-28 11:02    50  *******************************
0x000a  2            5  Device-to-host register FISes sent due to a COMRESET
0x8000  4        82446  Vendor specific
Message 6 of 10
jukkaforss
Tutor
sdd
root@readynas:~# smartctl -x /dev/sdd
Device Model:     WDC WD30EFRX-68EUZN0
Serial Number:    WD-WCC4N6CF8LYK
LU WWN Device Id: 5 0014ee 262e2cb16
Firmware Version: 82.00A82
Rotation Rate:    5400 rpm
Local Time is:    Fri Jun 28 11:02:57 2019 EEST
					was never started.
					been run.
data collection: 		(39060) seconds.
					command.
					power-saving mode.
recommended polling time: 	 ( 392) minutes.
SCT capabilities: 	       (0x703d)	SCT Status supported.
  1 Raw_Read_Error_Rate     POSR-K   200   200   051    -    0
  3 Spin_Up_Time            POS--K   213   194   021    -    4341
  4 Start_Stop_Count        -O--CK   100   100   000    -    33
  9 Power_On_Hours          -O--CK   066   066   000    -    25031
 10 Spin_Retry_Count        -O--CK   100   253   000    -    0
 11 Calibration_Retry_Count -O--CK   100   253   000    -    0
 12 Power_Cycle_Count       -O--CK   100   100   000    -    33
192 Power-Off_Retract_Count -O--CK   200   200   000    -    23
193 Load_Cycle_Count        -O--CK   200   200   000    -    2645
194 Temperature_Celsius     -O---K   102   100   000    -    48
                            ||||||_ K auto-keep
                            |||||__ C event count
                            ||||___ R error rate
No Errors Logged
# 1  Extended offline    Completed without error       00%     23976         -
# 2  Extended offline    Completed without error       00%     21858         -
# 3  Extended offline    Completed without error       00%     19655         -
# 4  Extended offline    Completed without error       00%     17448         -
# 5  Extended offline    Completed without error       00%     15244         -
# 6  Extended offline    Completed without error       00%     13103         -
# 7  Extended offline    Completed without error       00%     10902         -
# 8  Extended offline    Completed without error       00%      8704         -
# 9  Extended offline    Completed without error       00%      4357         -
#10  Extended offline    Completed without error       00%      2159         -
    1        0        0  Not_testing
    2        0        0  Not_testing
    3        0        0  Not_testing
    4        0        0  Not_testing
    5        0        0  Not_testing
Current Temperature:                    48 Celsius
Power Cycle Min/Max Temperature:     46/49 Celsius
Lifetime    Min/Max Temperature:      2/50 Celsius
Vendor specific:
Temperature History Size (Index):    478 (50)
  51    2019-06-28 03:05    48  *****************************
 ...    ..( 43 skipped).    ..  *****************************
  95    2019-06-28 03:49    48  *****************************
  96    2019-06-28 03:50    47  ****************************
 ...    ..( 51 skipped).    ..  ****************************
 148    2019-06-28 04:42    47  ****************************
 149    2019-06-28 04:43    48  *****************************
 ...    ..( 44 skipped).    ..  *****************************
 194    2019-06-28 05:28    48  *****************************
 195    2019-06-28 05:29    46  ***************************
 196    2019-06-28 05:30    46  ***************************
 197    2019-06-28 05:31    47  ****************************
 ...    ..( 33 skipped).    ..  ****************************
 231    2019-06-28 06:05    47  ****************************
 232    2019-06-28 06:06    46  ***************************
 ...    ..(261 skipped).    ..  ***************************
  16    2019-06-28 10:28    46  ***************************
  17    2019-06-28 10:29    47  ****************************
 ...    ..( 11 skipped).    ..  ****************************
  29    2019-06-28 10:41    47  ****************************
  30    2019-06-28 10:42    48  *****************************
 ...    ..( 19 skipped).    ..  *****************************
  50    2019-06-28 11:02    48  *****************************
0x0009  2            3  Transition from drive PhyRdy to drive PhyNRdy
0x8000  4        82448  Vendor specific
Message 7 of 10
jukkaforss
Tutor
sdb part 1
Serial Number:    WD-WMC1T3056108
LU WWN Device Id: 5 0014ee 658a0a0ff
Local Time is:    Fri Jun 28 11:11:34 2019 EEST
					was never started.
					been run.
data collection: 		(39120) seconds.
					command.
					power-saving mode.
recommended polling time: 	 ( 393) minutes.
  3 Spin_Up_Time            POS--K   210   178   021    -    4475
  4 Start_Stop_Count        -O--CK   100   100   000    -    134
 12 Power_Cycle_Count       -O--CK   100   100   000    -    134
193 Load_Cycle_Count        -O--CK   200   200   000    -    35
                            ||||||_ K auto-keep
                            |||||__ C event count
                            ||||___ R error rate
Device Error Count: 9
	CR     = Command Register
	FEATR  = Features Register
	COUNT  = Count (was: Sector Count) Register
	LBA_48 = Upper bytes of LBA High/Mid/Low Registers ]  ATA-8
	LH     = LBA High (was: Cylinder High) Register    ]   LBA
	LM     = LBA Mid (was: Cylinder Low) Register      ] Register
	LL     = LBA Low (was: Sector Number) Register     ]
	DV     = Device (was: Device/Head) Register
	DC     = Device Control Register
	ER     = Error register
	ST     = Status register
Powered_Up_Time is measured from power on, and printed as
DDd+hh:mm:SS.sss where DD=days, hh=hours, mm=minutes,
SS=sec, and sss=millisec. It "wraps" after 49.710 days.
  When the command that caused the error occurred, the device was active or idle.
  After command completion occurred, registers were:
  ER -- ST COUNT  LBA_48  LH LM LL DV DC
  40 -- 51 00 00 00 01 2f df 77 10 40 00  Error: UNC at LBA = 0x12fdf7710 = 5098141456
  Commands leading to the command that caused the error were:
  CR FEATR COUNT  LBA_48  LH LM LL DV DC  Powered_Up_Time  Command/Feature_Name
  60 00 10 00 60 00 00 67 4d 52 b0 40 08     01:04:39.235  READ FPDMA QUEUED
  61 00 40 00 58 00 01 24 f2 4a 00 40 08     01:04:39.235  WRITE FPDMA QUEUED
  61 00 40 00 50 00 01 24 f2 49 80 40 08     01:04:39.235  WRITE FPDMA QUEUED
  61 00 10 00 48 00 00 01 73 7a 18 40 08     01:04:39.235  WRITE FPDMA QUEUED
  60 00 80 00 40 00 01 2f df 76 c0 40 08     01:04:39.235  READ FPDMA QUEUED
  40 -- 51 00 00 00 01 2f df 77 10 40 00  Error: WP at LBA = 0x12fdf7710 = 5098141456
  61 00 40 00 50 00 01 24 f2 80 00 40 08     01:04:36.141  WRITE FPDMA QUEUED
  61 00 40 00 48 00 01 24 f2 7f c0 40 08     01:04:36.140  WRITE FPDMA QUEUED
  61 00 40 00 40 00 01 24 f2 59 c0 40 08     01:04:36.140  WRITE FPDMA QUEUED
  61 00 40 00 38 00 01 24 f2 56 00 40 08     01:04:36.140  WRITE FPDMA QUEUED
  61 00 40 00 30 00 01 24 f7 ad c0 40 08     01:04:36.140  WRITE FPDMA QUEUED
  40 -- 51 00 00 00 00 cf 08 38 40 40 00  Error: UNC at LBA = 0xcf083840 = 3473422400
  60 00 d0 00 00 00 00 04 bd 4a 40 40 08     02:27:16.202  READ FPDMA QUEUED
  60 01 80 00 f0 00 00 04 bd 48 40 40 08     02:27:16.202  READ FPDMA QUEUED
  60 01 80 00 e8 00 00 04 bd 46 40 40 08     02:27:16.202  READ FPDMA QUEUED
  60 01 80 00 e0 00 00 04 bd 44 40 40 08     02:27:16.202  READ FPDMA QUEUED
  60 01 80 00 d0 00 00 04 bd 40 40 40 08     02:27:16.202  READ FPDMA QUEUED
  40 -- 51 00 00 00 00 cf 08 38 40 40 00  Error: WP at LBA = 0xcf083840 = 3473422400
  61 00 40 00 a8 00 00 cf 02 e2 c0 40 08     02:27:13.298  WRITE FPDMA QUEUED
  60 00 d0 00 a0 00 00 04 bd 3a 40 40 08     02:27:13.289  READ FPDMA QUEUED
  60 01 30 00 98 00 00 04 bd 38 90 40 08     02:27:13.289  READ FPDMA QUEUED
  60 00 50 00 90 00 00 04 bd 38 40 40 08     02:27:13.280  READ FPDMA QUEUED
  60 00 b0 00 88 00 00 04 bd 37 10 40 08     02:27:13.280  READ FPDMA QUEUED
  40 -- 51 00 00 00 00 e8 24 a0 c0 40 00  Error: UNC at LBA = 0xe824a0c0 = 3894714560
  60 01 80 00 88 00 00 5a 64 0e 40 40 08     06:24:21.982  READ FPDMA QUEUED
  60 00 50 00 80 00 00 5a 64 10 40 40 08     06:24:21.982  READ FPDMA QUEUED
  60 00 08 00 78 00 00 e8 24 a0 c0 40 08     06:24:21.982  READ FPDMA QUEUED
  60 00 78 00 70 00 00 e8 24 a0 c8 40 08     06:24:21.982  READ FPDMA QUEUED
  60 00 30 00 68 00 00 5a 64 05 90 40 08     06:24:21.982  READ FPDMA QUEUED
  40 -- 51 00 00 00 00 e8 24 a0 b8 40 00  Error: WP at LBA = 0xe824a0b8 = 3894714552
  61 00 40 00 28 00 00 88 14 21 c0 40 08     06:24:19.084  WRITE FPDMA QUEUED
  60 00 80 00 20 00 00 e8 24 a0 40 40 08     06:24:19.084  READ FPDMA QUEUED
  60 00 78 00 18 00 00 e8 24 a0 c8 40 08     06:24:19.083  READ FPDMA QUEUED
  60 00 08 00 10 00 00 e8 24 a0 c0 40 08     06:24:19.083  READ FPDMA QUEUED
  60 00 50 00 08 00 00 5a 64 10 40 40 08     06:24:19.083  READ FPDMA QUEUED
  40 -- 51 00 00 00 00 e8 24 a0 b8 40 00  Error: UNC at LBA = 0xe824a0b8 = 3894714552
  60 01 80 00 50 00 00 e8 24 a0 40 40 08     06:24:16.156  READ FPDMA QUEUED
  60 00 80 00 48 00 00 e8 24 9f 40 40 08     06:24:16.156  READ FPDMA QUEUED
  ea 00 00 00 00 00 00 00 00 00 00 e0 08     06:24:16.131  FLUSH CACHE EXT
  61 00 01 00 38 00 00 00 90 00 48 40 08     06:24:16.131  WRITE FPDMA QUEUED
  40 -- 51 00 00 00 01 16 16 d4 b8 40 00  Error: WP at LBA = 0x11616d4b8 = 4665562296
  61 00 08 00 90 00 00 00 93 fe c0 40 08     02:53:56.605  WRITE FPDMA QUEUED
  60 00 80 00 88 00 01 16 16 d4 40 40 08     02:53:56.605  READ FPDMA QUEUED
  60 00 80 00 80 00 01 16 16 d4 c0 40 08     02:53:56.605  READ FPDMA QUEUED
  60 00 80 00 78 00 01 16 16 d5 40 40 08     02:53:56.605  READ FPDMA QUEUED
  60 00 08 00 70 00 00 00 71 98 98 40 08     02:53:56.605  READ FPDMA QUEUED
Message 8 of 10
jukkaforss
Tutor
sdb part 2
# 1  Extended offline    Completed without error       00%     51573         -
# 2  Extended offline    Completed without error       00%     49455         -
# 4  Extended offline    Completed without error       00%     45039         -
# 5  Extended offline    Completed without error       00%     42872         -
# 6  Extended offline    Completed without error       00%     40691         -
# 8  Extended offline    Completed without error       00%     36311         -
#10  Extended offline    Completed without error       00%     29750         -
#12  Extended offline    Completed without error       00%     25341         -
#17  Extended offline    Completed without error       00%     14452         -
    1        0        0  Not_testing
    2        0        0  Not_testing
    3        0        0  Not_testing
    4        0        0  Not_testing
    5        0        0  Not_testing
Vendor specific:
Temperature History Size (Index):    478 (203)
 204    2019-06-28 03:14    49  ******************************
 213    2019-06-28 03:23    49  ******************************
 214    2019-06-28 03:24    48  *****************************
 ...    ..( 47 skipped).    ..  *****************************
 262    2019-06-28 04:12    48  *****************************
 263    2019-06-28 04:13    47  ****************************
 ...    ..( 14 skipped).    ..  ****************************
 278    2019-06-28 04:28    47  ****************************
 279    2019-06-28 04:29    48  *****************************
 ...    ..( 26 skipped).    ..  *****************************
 306    2019-06-28 04:56    48  *****************************
 307    2019-06-28 04:57    47  ****************************
 316    2019-06-28 05:06    47  ****************************
 317    2019-06-28 05:07    48  *****************************
 ...    ..(  5 skipped).    ..  *****************************
 323    2019-06-28 05:13    48  *****************************
 324    2019-06-28 05:14    47  ****************************
 342    2019-06-28 05:32    47  ****************************
 343    2019-06-28 05:33    48  *****************************
 ...    ..(141 skipped).    ..  *****************************
   7    2019-06-28 07:55    48  *****************************
   8    2019-06-28 07:56    47  ****************************
 ...    ..( 10 skipped).    ..  ****************************
  19    2019-06-28 08:07    47  ****************************
  20    2019-06-28 08:08    48  *****************************
  37    2019-06-28 08:25    48  *****************************
  38    2019-06-28 08:26    49  ******************************
 ...    ..( 97 skipped).    ..  ******************************
 136    2019-06-28 10:04    49  ******************************
 137    2019-06-28 10:05    48  *****************************
 155    2019-06-28 10:23    48  *****************************
 156    2019-06-28 10:24    49  ******************************
 173    2019-06-28 10:41    49  ******************************
 174    2019-06-28 10:42    50  *******************************
 ...    ..( 23 skipped).    ..  *******************************
 198    2019-06-28 11:06    50  *******************************
 199    2019-06-28 11:07    49  ******************************
 203    2019-06-28 11:11    49  ******************************
0x8000  4        82963  Vendor specific
Message 9 of 10
Guru
@jukkaforss wrote:
sdb part 1
Message 10 of 10
Top Contributors
Discussion stats
  • 9 replies
  • 1942 views
  • 0 kudos
  • 2 in conversation
Announcements
