× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
power supply failure (can I order new one?)
Heba
Model: ReadyNAS RNDP6350|ReadyNAS Pro 6
Message 1 of 4
Heba
Re: power supply failure (can I order new one?)
After a powe outage my data storage is dead, I am looking to order a new replacement for the power supply, can anyone please guide me on how and where to order it from?
Thanks
Message 2 of 4
JennC
NETGEAR Employee Retired
Hello Heba,
Are you referring to the power cable which is the same with what we use on desktop computers or the internal component power supply?
It may be best to check with the support team first if it still has warranty.
Welcome to the community!
Message 3 of 4
Sandshark
Sensei
The exact replacement supply has never been available from Netgear, even when the Pro6 was an active model, except as a warranty item.  The same base supply (Seasonic SS-300SFD) is $40 plus shipping from NewEgg.  The Netgear version has a custom wire harness.  You will need a 6" 24-pin ATX extender with the replacement supply.  You may choose to trim down the drive power wires and move the 4-pin Molex connectors from the original supply to the replacement to reduce excess cabling.
If you need more information, do a forum search.  There are several threads on this.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 769 views
  • 0 kudos
  • 3 in conversation
Announcements
