× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
problems after firmware upgrade to 6.10.1
bouellette
I upgraded by ReadyNAS212 to 6.10.1. Couple of things happened.
Raidar could no longer connect to it... but I could connect to it
by typing directly into my browser.
Also.. on the network (MAC OS10.12)...  my network shows
the name with a ? after it...
The NAS is functioning but really really slow. I reloaded the firmware.. and that helped
for only a short while. It did reset the ip address... and I set it back to the static ip...
but still slow... The ACT light is on a constant blinking.... When I connect to it through
browser it doesn't show any errors.
Model: RN212D22|ReadyNAS 212 Series 2- Bay (2x 2TB Desktop)
Message 1 of 7
Marc_V
NETGEAR Employee Retired
Re: problems after firmware upgrade to 6.10.1
Hi @bouellette
Welcome to the Community!
When you mean reloaded the firmware is it USB recovery or just OS Reinstall? If it's OS Reinstall it might not always resolve any issues with the NAS. Have you checked the logs? Kindly send it to us through PM using google drive if possible so we can help. There might be underlying issues and is not really caused by the update so checking the logs would be best.
Hope this helps!
Regards
Message 2 of 7
Marc_V
Hi @bouellette
Is the NAS not showing on RAIDar? Also, do you have any apps installed?
Is the Admin page slow or the NAS operation is slow (read/Write)?
Regards
Message 3 of 7
bouellette
The NAS shows on the Raidar... but you cannot connect ... the Admin tries to connect...
but them comes up with the error page that says it's either turned off or busy.
I can connect quickly through any browser. I'm attaching a screenshot of my
network connections ... before all this... I did not have a ? in front of the server
and you could see all the shares.... We connect through the AFP...
It seems to be running much faster now... after a complete rebot of modem, router, switch, etc.
Also...  on the NAS... the ACT light is a constant blinking blue light... The other older
NAS drives I have... that light is solid blue.
Message 4 of 7
alboccio1
I believe Raidar requires 32 bit Java.  I had to install the 32 bit vesion before Raidar worked.
I have adifferent problem, after the update to 6.10.1 all of the graphs in the Performance page disappeared.  I'm going to downgrade to 6.10.0
Model: RN212|2 BAY Desktop ReadyNAS Storage
Message 5 of 7
bouellette
Raidar sees the NAS... but when you click on the Admin page and try
to log in it is very slow.. and then you get an error message saying the drive
is off or busy. When you connect through a browser it connects immediately.
I will try the Java fix.
Attaching screenshot of how my network connections look on my mac.
Before this upgrade the server appeared differently. It didn't have a ? in front of it,
and it showed all the servers in the main list... although you could not connect that way.
We connect through AFP.
The NAS appears to be working well now... we are on deadline today to publish and
the speed is acceptable.... just odd these two things just not acting correctly.
Also.. one mac could connect .. but in the "get info" box it showed up as connected
under volume/AdDesignNew... not afp://GraphicsServer(AFP)... etc.  She could open
the volume but it was blank.
Just weird little things happening.
Also. in the Screenshot... the GraphicsServer shows up all caps.. just can't remember
if that's how it displayed before...
Message 6 of 7
Guru
@alboccio1 wrote:
I have a different problem, after the update to 6.10.1 all of the graphs in the Performance page disappeared.  I'm going to downgrade to 6.10.0
What's odd here is that you shouldn't have seen any graphs on the RN212's performance page before.  Performance graphs are only available on the x86 NAS (RN300 and above).
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 2179 views
  • 0 kudos
  • 4 in conversation
Announcements
