- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
"(null)+0" on RN516 front display
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have a rn516, it cannot boot up after normal restart. It shown null +0 and the panel
Thanks
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
It could be caused by an add-on crashing for example, but that error is very generic so there are a range of possibilities.
Useful links: Sending Logs|My ReadyNAS Gear|FAQ|Hardware Compatibility List|Docs: Setup Guide, Manual|Downloads|Unofficial Tips|GPL|MDGM on Twitter|MDGM's Unofficial Guides
NB: A ReadyNas is not an excuse not to have a backup. Fire, theft, multiple disk failures, other hardware failure, floods, user negligence etc. can all result in loss of data.
How to contact NETGEAR Technical Support | Australia: 1300 361 254 / Other Numbers|Online Submission
Unofficial Guide for Moving from Sparc ReadyNAS to x86 ReadyNAS|Using Gmail with the ReadyNAS|XRAID Volume Size Calculator
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: "(null)+0" on RN516 front display
You likely need support via my.netgear.com.
If you purchased your NAS (new) between 1 June 2014 and 31 May 2016, then you have lifetime free chat support.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks stephen first
but anyone encountered the same issue, can any one give me some hints first?
- Mark as New
- Bookmark
- Subscribe
- Permalink
You could try forcibly powering down the NAS, and then restart it. Likely that will work, but the problem might recur.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks and Mdgm and Stephen
the addon -syslog fill up the root partition, after deleted the /var/log files and reboot , it resumed to normal!
Thanks for your help and wish you 2 a very happy new year!
- Mark as New
- Bookmark
- Subscribe
- Permalink
If you don't remove the add-on that created the large log file then the problem will likely come back.
- Mark as New
- Bookmark
- Subscribe
- Permalink
