× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
ready nas duo v2 from 2 x 1TB to 2 x 2TB
Basti1970
Follower
Than
Than
Dear Community,
we have an ReadyNas Duo v2 with 2 x 1TB installed.
Now we would like to uprade to 2 x 2TB.
Is it easy to upgrade? ... The next problem is,
that the recommendet HD for exampel WD Red WD20EFRX is not avalible,
can i also use an WD20EFAX ?
Thanks for your solutions.
Model: RND2000v2|ReadyNAS Duo v2 Chassis only
Message 1 of 2
Guru
Re: ready nas duo v2 from 2 x 1TB to 2 x 2TB
that the recommended HD for exampel WD Red WD20EFRX is not avalible,
I don't recommend the WD20EFAX.  Instead use the WD20EFZX (in the Red Plus line).  Note the WD20EFRX was rebranded as Red Plus a while ago, and the W20EFZX replaces it.  https://www.anandtech.com/show/15878/western-digital-cleans-up-the-red-smr-nas-hdd-mess
The WD20EFAX uses SMR technology, which is not well suited to RAID.  While it might work out in the Duo, it is best avoided.
The Seagate Ironwolf (ST2000VN004) would also work.
Now we would like to upgrade to 2 x 2TB.
Yes.  It is best to begin by backing up your data (just in case the disks fail during that process).  Personally I also test the new drives in a Windows PC using vendor tools (WDC dashboard or Seagate's Seatools) before adding them to my ReadyNAS.
Then hot-swap the first drive with the new larger one (with the NAS running).  Wait for the RAID to resync before proceeding further.
After the RAID resyncs, hot-swap the second drive.  There will be another resync.  After that the volume will expand.  The second step (which includes the expansion) will take about twice as long as the first step.
The NAS might prompt you to reboot during this second step, so look out for that.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1022 views
  • 1 kudo
  • 2 in conversation
Announcements
