- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
readynas 2100 3rf disk led power off
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi,
when I power on my used readynas 2100 the 3rd disk led is power off, instead the 1/2/4 disk led and power led are still power on.
What's the problem?
Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: readynas 2100 3rf disk led power off
@Retired_Member wrote:when I power on my used readynas 2100 the 3rd disk led is power off, instead the 1/2/4 disk led and power led are still power on.
Does the admin web ui show that the disk is operational? Or that the array is degraded?
Have you downloaded the log zip file, and looked in there?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I can't access via web gui, I've already tried with the usb boot without any positive resolution.
- Mark as New
- Bookmark
- Subscribe
- Permalink
What happens when you try?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Chrome says connection denied and raidradar no nas found =(
- Mark as New
- Bookmark
- Subscribe
- Permalink
Do you know what firmware you are running?
Can you ping the NAS?
Is ssh enabled?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I can Ping it but no ssh access even after the factory reset (is it 3rd light?)
The factory reset will delete your data - is that something you are ok with?
See page 12 of the hardware manual
The disk 3 light selects the OS reinstall; the disk 2 light selects the factory reset.
I suggest powering down the NAS and removing the disks. Label the disks as you remove them, so you can preserve slot order. Power up, and see if RAIDar finds it, and gives you a no-disks statuss.
It would also be useful to test the disks in a Windows PC with vendor tools (WDC's Sashboard, or Seagate's Seatools). You can connect the disks either with SATA or a USB adapter/dock.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Is it possible to make the reinstall from usb?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I tried the factory reset (2nd light) and still power light on (no blinking).
If that worked, then the drives would be formatted and the OS installed.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Unfortunally no, there are 4 new HDDs of 2TB each one.
Let us know what happens with the no-disks test.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
The 2100 is an OS4.2.x device and this sound like the TLS1.0 issue that's already been discussed in dozens of posts. Have you tried any of the work-arounds already discussed?
What does RAIDar show?
- Mark as New
- Bookmark
- Subscribe
- Permalink
RAIDar shows "no devices found".
I've also change the power supply to avoid any problem with that.
I'm stuck to see what could be the problem but without any resolution...
- Mark as New
- Bookmark
- Subscribe
- Permalink
Test done without positive result, I attach some photos
Your first screenshot is an app showing the RN104 - not a 2100. So I am confused on why you posted it.
- Do you also own an RN104?
- Did the 2100 ever work for you? Or did you just purchase it, and can't get it up and running?
When you connect to https://nas-ip-address/admin (using the real NAS IP address of course) - are you seeing an SSL protocol or Cipher Mismatch error?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'm sure it's a 2100, the image is wrong but from UniFi there is no 2100. The nas comes from a customer of mine, who has abandoned all the CED and I recovered the NAS without the disks so as not to have his data.
When I connect to the IP address https://192.168.0.155/admin it immediately gives me a "connection denied" error as if the NAS is booting or crashed
It's very frustrating because I've had quite a few ReadyNAS but this one is driving me crazy, I've even tried reinstalling via USB, no success.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Have you ever used tech support mode?
- Mark as New
- Bookmark
- Subscribe
- Permalink
is it what happens by pressing the "act/reset" button before turning it on, until all 4 harddisk lights are on?
- Mark as New
- Bookmark
- Subscribe
- Permalink
It's the tech support boot menu option described on page 13 here:
When you are in that mode, you can access the linux command line by connecting with telnet. That would let you look at disk health, and see if the OS partition was installed on the disks.
Note step 6 in the manual (press and release reset to confirm the selection). It's easy to overlook that step, since it is after the table.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks StephenB, I didn't know telnet was available in that case!
I know the credentials are root, the password is infr8ntdebug
Are the telnet commands I can run the usual ones?
I would try to turn it on without disks and go into tech support mode, do you think I can access via telnet the same? So as to check if I have to reinstall the NAND via usb or not.
For point 6, yes the first few times it can escape, but you realize when it catches it because it reboots.
- Mark as New
- Bookmark
- Subscribe
- Permalink
The linux you are running is in the flash memory, so there are commands that are missing. Not sure which ones they are though. Hopefully smartctl is installed
If the disks are installed and the OS partition is there, then you can do this:
start_raid.sh
mount /dev/md0 /sysroot
to start the RAID array and mount the OS partition on the disks.
If the OS partition mounts, you can then chroot using
mount bind /proc /sysroot/proc
mount bind /dev /sysroot/dev
mount bind /dev/pts /sysroot/dev/pts
mount bind /sys /sysroot/sys
chroot /sysroot /bin/bash
The internal flash is visible - you can look for it in
cat /proc/partitions
It should be the smallest disk with a single partition. You can then mount that using something like
mount /dev/sdg1 /mnt
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi StephenB,
I tried but as you can see in the screenshot there is something wrong, I will try to replace the disks.
Thanks
