× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
readynas 2100 3rf disk led power off
Guru
Re: readynas 2100 3rf disk led power off
@Retired_Member wrote:
I tried but as you can see in the screenshot there is something wrong, I will try to replace the disks.
Have you tested any of these disks?  It does sound like one (or more) aren't healthy.
Try with only one disk so assembling the raid volume isn't an issue.  You can either try another factory reset with just one disk installed, or you can remove the partitions on a Windows PC (or zero the disk to return it to a blank condition).  The NAS will automatically do a factory install if you power up with an unformated disk installed.
Message 26 of 29
Sandshark
Sensei
Can you connect the NAS directly to the PC and see if RAIDar then finds it?  You'd have to change the PC's IP address to connect that way, but it would at least verify that it's not the Unifi system that's blocking you.
Message 27 of 29
Retired_Member
Not applicable
StephenB unfortunately after a reboot no longer gives the option to enter the boot menu. The 4 LEDs remain off even though the 15 seconds with the reset button pressed after switching on have passed. I know something is corrupted
Message 28 of 29
Retired_Member
Not applicable
Thanks Sandshark, I tried that too, but at the moment the ReadyNAS doesn't seem to boot
Message 29 of 29
Top Contributors
Discussion stats
  • 28 replies
  • 2888 views
  • 1 kudo
  • 3 in conversation
Announcements
