× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
readynas pro 6 stuck in boot/check root FS/check FS loop
mdgm
Virtuoso
Re: readynas pro 6 stuck in boot/check root FS/check FS loop
My suspicion is that there may be a spool script to shutdown the NAS left behind in /var/spool/frontview on the sysroot. If this is the case the system will get stuck in a reboot loop until the script is removed.
Message 26 of 53
Number6
thanks...I think...
Here's what happened:
# start_raid.sh
mdadm: /dev/md/0 has been started with 5 drives (out of 6).
mdadm: /dev/md/1 has been started with 6 drives.
mdadm: /dev/md/2 has been started with 6 drives.
mdadm: /dev/md/0 already active, cannot restart it!
mdadm: /dev/md/0 needed for /dev/sda1...
# Connection closed by foreign host.
and now the Pro 6 is no longer visible by Raidair.
Message 27 of 53
Guru
Interesting.  I think you'll need to boot up in tech support mode again, and try to start RAID for md0 manually.
Message 28 of 53
mdgm
Virtuoso
One of the disks has dropped out of the RAID array for the root volume.
You could check the state of the root RAID array by doing e.g.
# mdadm --examine /dev/sd[a-z]1 | egrep -i 'sd|event|uuid|recovery|super|role|update'
# for i in /dev/sd[a-z]1; do echo $i;  mdadm -E $i | egrep "Creat|Update|State|Raid"; done;
You may also wish to check the SMART stats of the disks to see if there is a problem disk
# for i in a b c d e f g h i j k l m n; do smartctl -a /dev/sd${i} | egrep -i "Device Model|Serial Number|Reallocated_sec|ATA Er|offline_uncorrect|current_pending_sector|Power_on"; done
# for i in /dev/sd[a-z]; do echo $i; smartctl -a $i | egrep "Model|Serial|Firm|Sector|Hours|Error|Uncorr"; done;
Message 29 of 53
Number6
(yes, I know I'll have to reboot into tech support mode "each time")
Thanks. here's lots of results... still trying to figure out what to do:
(1) # mdadm --examine /dev/sd[a-z]1 | egrep -i 'sd|event|uuid|recovery|super|role|update'
/dev/sda1:
Array UUID : c8a57984:570f900c:6fbe8815:6febea3f
Super Offset : 8 sectors
Device UUID : 5d34be00:4ca6ea2d:064fec68:bfeffdee
Update Time : Sun Feb 7 23:19:05 2021
Events : 2864
/dev/sdb1:
Device UUID : a0429c31:96db2c16:990aeabe:47a89640
Events : 2864
/dev/sdc1:
Device UUID : 0a00bff0:2340dc15:8529ebd1:f0e0ed9d
Events : 2864
/dev/sdd1:
Device UUID : c74b6a70:98908d4c:fca771fd:0ac7b738
Events : 2864
/dev/sde1:
Device UUID : 6742adae:a354e3be:75b11fcf:c220e183
Events : 2864
/dev/sdf1:
Device UUID : 5c201efc:7c3cc971:3b14d652:f52c1d3b
Events : 2864
mdadm: No md superblock detected on /dev/sdg1.
(2) # for i in /dev/sd[a-z]1; do echo $i; mdadm -E $i | egrep "Creat|Update|State|Raid"; done;
/dev/sda1
Creation Time : Mon Dec 12 17:51:52 2011
Raid Level : raid1
Raid Devices : 6
State : active
Array State : Uuuuuu 378 failed
/dev/sdb1
Raid Level : raid1
Raid Devices : 6
State : active
Array State : uUuuuu 378 failed
/dev/sdc1
Raid Level : raid1
Raid Devices : 6
State : active
Array State : uuUuuu 378 failed
/dev/sdd1
Raid Level : raid1
Raid Devices : 6
State : active
Array State : uuuUuu 378 failed
/dev/sde1
Raid Level : raid1
Raid Devices : 6
State : active
Array State : uuuuUu 378 failed
/dev/sdf1
Raid Level : raid1
Raid Devices : 6
State : active
Array State : uuuuuU 378 failed
/dev/sdg1
(3) # for i in a b c d e f g h i j k l m n; do smartctl -a /dev/sd${i} | egrep -i "Device Model|Serial Num
Device Model: Hitachi HDS723030ALA640
Serial Number: MK0331YHGUJ54A
5 Reallocated_Sector_Ct 0x0033 100 100 005 Pre-fail Always - 0
9 Power_On_Hours 0x0012 089 089 000 Old_age Always - 79717
197 Current_Pending_Sector 0x0022 100 100 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0008 100 100 000 Old_age Offline - 0
Serial Number: MK0331YHGUEX4A
9 Power_On_Hours 0x0012 089 089 000 Old_age Always - 79855
ATA Error Count: 1
Serial Number: MK0331YHGEHWNA
9 Power_On_Hours 0x0012 089 089 000 Old_age Always - 79860
ATA Error Count: 31 (device log contains only the most recent five errors)
Serial Number: MK0331YHGUA3RA
9 Power_On_Hours 0x0012 089 089 000 Old_age Always - 79718
Serial Number: MK0331YHGUJ8BA
Serial Number: MK0331YHGUJ5HA
(4) # for i in /dev/sd[a-z]; do echo $i; smartctl -a $i | egrep "Model|Serial|Firm|Sector|Hours|Error|Unco
rr"; done;
/dev/sda
Firmware Version: MKAOA5C0
Error logging capability: (0x01) Error logging supported.
1 Raw_Read_Error_Rate 0x000b 100 100 016 Pre-fail Always - 0
7 Seek_Error_Rate 0x000b 100 100 067 Pre-fail Always - 0
199 UDMA_CRC_Error_Count 0x000a 200 200 000 Old_age Always - 0
SMART Error Log Version: 1
No Errors Logged
/dev/sdb
199 UDMA_CRC_Error_Count 0x000a 200 200 000 Old_age Always - 1
ATA Error Count: 1
SC = Sector Count Register [HEX]
SN = Sector Number Register [HEX]
ER = Error register [HEX]
Error 1 occurred at disk power-on lifetime: 130 hours (5 days + 10 hours)
/dev/sdc
199 UDMA_CRC_Error_Count 0x000a 200 200 000 Old_age Always - 31
Error 31 occurred at disk power-on lifetime: 128 hours (5 days + 8 hours)
Error 30 occurred at disk power-on lifetime: 128 hours (5 days + 8 hours)
Error 29 occurred at disk power-on lifetime: 128 hours (5 days + 8 hours)
Error 28 occurred at disk power-on lifetime: 128 hours (5 days + 8 hours)
Error 27 occurred at disk power-on lifetime: 128 hours (5 days + 8 hours)
/dev/sdd
No Errors Logged
/dev/sde
No Errors Logged
/dev/sdf
No Errors Logged
/dev/sdg
Message 30 of 53
mdgm
Virtuoso
That's interesting. They all show the same update time. The drives appear to be healthy (although there are some ATA errors they were all a very long time ago).
Message 31 of 53
Number6
... more ...
(5)
/dev/sda1:
         Events : 2864
/dev/sdb1:
         Events : 2864
/dev/sdc1:
         Events : 2864
/dev/sdd1:
         Events : 2864
/dev/sde1:
         Events : 2864
/dev/sdf1:
         Events : 2864
(6) # for i in /dev/sd[a-z]1; do echo $i;  mdadm -E $i | egrep "Creat|Update|State|Raid"; done;
/dev/sda1
     Raid Level : raid1
   Raid Devices : 6
          State : active
/dev/sdb1
     Raid Level : raid1
   Raid Devices : 6
          State : active
/dev/sdc1
     Raid Level : raid1
   Raid Devices : 6
          State : active
/dev/sdd1
     Raid Level : raid1
   Raid Devices : 6
          State : active
/dev/sde1
     Raid Level : raid1
   Raid Devices : 6
          State : active
/dev/sdf1
     Raid Level : raid1
   Raid Devices : 6
          State : active
/dev/sdg1
Message 32 of 53
Number6
... more...
(7) # for i in a b c d e f g h i j k l m n; do smartctl -a /dev/sd${i} | egrep -i "Device Model|Serial Num
ATA Error Count: 1
Message 33 of 53
Number6
... more ...
(8) # for i in /dev/sd[a-z]; do echo $i; smartctl -a $i | egrep "Model|Serial|Firm|Sector|Hours|Error|Unco
rr"; done;
/dev/sda
No Errors Logged
/dev/sdb
ATA Error Count: 1
/dev/sdc
/dev/sdd
No Errors Logged
/dev/sde
No Errors Logged
/dev/sdf
No Errors Logged
/dev/sdg
Message 34 of 53
Number6
... LAST ...
(9) # `ifconfig eth0 | awk '/HWaddr/ { gsub(":","",$5); print $5 }'`
   001F33EADAB1
(10) # mdadm -A -f -v -v --scan --homehost=001F33EADAB1 --auto-update-homehost --auto=md
mdadm: looking for devices for further assembly
mdadm: no recogniseable superblock on /dev/sda
mdadm: no recogniseable superblock on /dev/sdb
mdadm: no recogniseable superblock on /dev/sdc
mdadm: no recogniseable superblock on /dev/sdd
mdadm: no recogniseable superblock on /dev/sde
mdadm: no recogniseable superblock on /dev/sdf
mdadm: no recogniseable superblock on /dev/sdg
mdadm: no RAID superblock on /dev/sdg1
mdadm: /dev/sda1 is identified as a member of /dev/md/0, slot 0.
mdadm: /dev/sdb1 is identified as a member of /dev/md/0, slot 1.
mdadm: /dev/sdc1 is identified as a member of /dev/md/0, slot 2.
mdadm: /dev/sdd1 is identified as a member of /dev/md/0, slot 3.
mdadm: /dev/sde1 is identified as a member of /dev/md/0, slot 4.
mdadm: /dev/sdf1 is identified as a member of /dev/md/0, slot 5.
mdadm: added /dev/sdb1 to /dev/md/0 as 1
mdadm: added /dev/sdc1 to /dev/md/0 as 2
mdadm: added /dev/sdd1 to /dev/md/0 as 3
mdadm: added /dev/sde1 to /dev/md/0 as 4
mdadm: added /dev/sdf1 to /dev/md/0 as 5
mdadm: added /dev/sda1 to /dev/md/0 as 0
mdadm: /dev/md/0 has been started with 6 drives.
mdadm: no recogniseable superblock on /dev/sdg1
mdadm: /dev/sda2 is identified as a member of /dev/md/1, slot 0.
mdadm: /dev/sdb2 is identified as a member of /dev/md/1, slot 1.
mdadm: /dev/sdc2 is identified as a member of /dev/md/1, slot 2.
mdadm: /dev/sdd2 is identified as a member of /dev/md/1, slot 3.
mdadm: /dev/sde2 is identified as a member of /dev/md/1, slot 4.
mdadm: /dev/sdf2 is identified as a member of /dev/md/1, slot 5.
mdadm: added /dev/sdb2 to /dev/md/1 as 1
mdadm: added /dev/sdc2 to /dev/md/1 as 2
mdadm: added /dev/sdd2 to /dev/md/1 as 3
mdadm: added /dev/sde2 to /dev/md/1 as 4
mdadm: added /dev/sdf2 to /dev/md/1 as 5
mdadm: added /dev/sda2 to /dev/md/1 as 0
mdadm: /dev/sda3 is identified as a member of /dev/md/2, slot 0.
mdadm: /dev/sdb3 is identified as a member of /dev/md/2, slot 1.
mdadm: /dev/sdc3 is identified as a member of /dev/md/2, slot 2.
mdadm: /dev/sdd3 is identified as a member of /dev/md/2, slot 3.
mdadm: /dev/sde3 is identified as a member of /dev/md/2, slot 4.
mdadm: /dev/sdf3 is identified as a member of /dev/md/2, slot 5.
mdadm: added /dev/sdb3 to /dev/md/2 as 1
mdadm: added /dev/sdc3 to /dev/md/2 as 2
mdadm: added /dev/sdd3 to /dev/md/2 as 3
mdadm: added /dev/sde3 to /dev/md/2 as 4
mdadm: added /dev/sdf3 to /dev/md/2 as 5
mdadm: added /dev/sda3 to /dev/md/2 as 0
mdadm: no recogniseable superblock on /dev/md/2
mdadm: no recogniseable superblock on /dev/md/1
mdadm: no recogniseable superblock on /dev/md/0
mdadm: cannot open device /dev/sda: Device or resource busy
mdadm: cannot open device /dev/sdb: Device or resource busy
mdadm: cannot open device /dev/sdc: Device or resource busy
mdadm: cannot open device /dev/sdd: Device or resource busy
mdadm: cannot open device /dev/sde: Device or resource busy
mdadm: cannot open device /dev/sdf: Device or resource busy
mdadm: cannot open device /dev/sda1: Device or resource busy
mdadm: cannot open device /dev/sdb1: Device or resource busy
mdadm: cannot open device /dev/sdc1: Device or resource busy
mdadm: cannot open device /dev/sdd1: Device or resource busy
mdadm: cannot open device /dev/sde1: Device or resource busy
mdadm: cannot open device /dev/sdf1: Device or resource busy
mdadm: cannot open device /dev/sda2: Device or resource busy
mdadm: cannot open device /dev/sdb2: Device or resource busy
mdadm: cannot open device /dev/sdc2: Device or resource busy
mdadm: cannot open device /dev/sdd2: Device or resource busy
mdadm: cannot open device /dev/sde2: Device or resource busy
mdadm: cannot open device /dev/sdf2: Device or resource busy
mdadm: cannot open device /dev/sda3: Device or resource busy
mdadm: cannot open device /dev/sdb3: Device or resource busy
mdadm: cannot open device /dev/sdc3: Device or resource busy
mdadm: cannot open device /dev/sdd3: Device or resource busy
mdadm: cannot open device /dev/sde3: Device or resource busy
mdadm: cannot open device /dev/sdf3: Device or resource busy
Message 35 of 53
mdgm
Virtuoso
Try assembing just md0 and see if the connection remains up doing that.
It's strange that you are losing connection when assembling the RAID. One wonders if the crashing could be due to some kind of hardware problem, whether a disk or some other hardware e.g. the PSU.
Message 36 of 53
Number6
Thanks very much!
(1) The connection drops because it reboots into the boot loop.
(2) How would I assemble just md0?
(3) going back to previous trouble shooting... Taking out all drives and installing a "new" (ok, old from somewhere) drive) it boots aok (wipes that drive and fully boots to factory defaults up and all running. So, that rules out the main hardware and drive 0 hardware (not the drive itself, though). BUT, it boots into that loop when I install only five drives leaving drive 0 removed.
Message 37 of 53
mdgm
Virtuoso
The power requirements for one drive are less than for more than one drive.
With the scratch disk (not from your array) can you try booting from in it from each slot, not just the first drive bay, if you haven't already?
Message 38 of 53
Number6
booted six times -- moving that spare drive from slot to slot. all booted aok.
Went back into "debug mode" (that's what was displayed on the LEDs this time); logged in; and did
mdadm -A -f -vv --scan --homehost=001F33EADAB1 --auto-update-homehost --auto=md
Results were (and then terminal was still active for a while... then it rebooted):
Any more ideas?
Message 39 of 53
mdgm
Virtuoso
That would seem to suggest that the SATA backplane is probably fine.
If the disks are fine, then I guess it would point to a problem on the disks, or looking at doing a memory test of the RAM (if not done already) or perhaps a problem with the PSU.
Try starting just the 4GB root volume. I think from memory it's something like this:
# mdadm --assemble /dev/md0 /dev/sda1 /dev/sdb1 /dev/sdc1 /dev/sdd1 /dev/sde1 /dev/sdf1
If that works you could mount the sysroot and have a look around in that.
Message 40 of 53
Number6
I did that and then telnet "hung", then it started rebooting.
HERE:
# mdadm -vv --assemble /dev/md0 /dev/sda1 /dev/sdb1 /dev/sdc1 /dev/sdd1 /dev/sde1 /dev/sdf1
mdadm: looking for devices for /dev/md0
mdadm: /dev/sda1 is identified as a member of /dev/md0, slot 0.
mdadm: /dev/sdb1 is identified as a member of /dev/md0, slot 1.
mdadm: /dev/sdc1 is identified as a member of /dev/md0, slot 2.
mdadm: /dev/sdd1 is identified as a member of /dev/md0, slot 3.
mdadm: /dev/sde1 is identified as a member of /dev/md0, slot 4.
mdadm: /dev/sdf1 is identified as a member of /dev/md0, slot 5.
mdadm: added /dev/sdb1 to /dev/md0 as 1
mdadm: added /dev/sdc1 to /dev/md0 as 2
mdadm: added /dev/sdd1 to /dev/md0 as 3
mdadm: added /dev/sde1 to /dev/md0 as 4
mdadm: added /dev/sdf1 to /dev/md0 as 5
mdadm: added /dev/sda1 to /dev/md0 as 0
mdadm: /dev/md0 has been started with 6 drives.
If no other ideas (more ideas would be MOST appreciated!), then should I:
(A) Pay $400 for service
or
(B) Pay $250-400 for a replacement unit on ebay -- hoping that my drives will just work in that unit.
Message 41 of 53
mdgm
Virtuoso
If the system crashes doing a simple thing like starting the RAID then paying for software service is going to be a waste of time unless it's just that one of the disks is bad and needs to be removed or cloned or something like that.
The problem is either:
  • failing PSU
  • bad disk
  • some other hardware issue e.g. RAM etc.
Have you run the memory test boot menu option for at least a few passes?
Have you tried the disk test boot menu option and/or done e.g.
# smartctl -t long /dev/sda
Seeing your system is crashing I would wait for each disk's test to finish before trying the next one if you do this.
If you are confident the disks are fine and don't want to go down the route of trying replacing the PSU and/or RAM, then getting a new NAS e.g. RN426, RN526X etc. and moving the disks across is probably what should be tried next.
Message 42 of 53
Number6
Hadn't run the boot mode tests yet. Ran smartctl smarttest on all six seemingly ok. starting a long test on sda now.
If it's a bad disk, then shouldn't I be able to try booting with one disk removed at a time? Thinking it might be disk 0, I did try that but it didn't work. If that's a good test for a bad drive, then I'll do it and if it works with just one removed, then I can replace that drive.
I've hunted on the bay for RN426 OR RN526X and didn't find any. Are those the only 6 bay units that are upward compatible with my Pro 6? -- i.e. that I can just plug my six drives in and they should just work? Going that way sounds attractive since I could upgrade to 4-8GB drives (the Pro is stuck at 3GB drives max).
Message 43 of 53
mdgm
Virtuoso
The latest models are RN426, RN428, RN526X, RN528X, RN626X, RN628X
Older OS6 models are RN316, RN516 and RN716X
If the disks, array and OS are fine it will boot with the volume read-only so you can copy your data off, then do a factory reset (wipes all data, settings, everything) and restore data from backup.
I don't recommend getting RAIDiator-x86 units (e.g. Ultra, Ultra Plus, Pro) unless you really love buying old hardware. They would all have been manufactured over 8 years ago and thus even if in working condition now, are more likely to fail sooner.
Your Pro is not limited to 3TB disks, however upgrading to higher capacity disks whilst staying on RAIDiator-x86 would run into expansion limitations.
Message 44 of 53
mdgm
Virtuoso
You could, however I don't like to do it that way. If the disks become out of sync it could force a resync leading to further problems.
It sounds to me like most likely it's a PSU issue with spinning up all the disks drawing too much power from a failing PSU. One way to test this theory would be to put 6 scratch disks in and see if it enters the reboot loop. If it doesn't enter the reboot loop then it would suggest a bad disk.
If you remove the PSU you can inspect it to see if it's damaged. PSUs are one of the most likely components to fail in a PC and they have failed in a number of Pro units. It's hardly surprising that PSUs are failing well after the warranty has expired.
Message 45 of 53
Sandshark
Sensei
No OS6 unit will have that level of compatibility unless the Pro6 was converted to OS6 (and I can see yours wasn't).  You can put the drives from your unit in one in order to recover data in a read-only mode, but it won't "just work" as a production NAS.
If you have an ATX power supply lying around, you could connect it externally in place of the internal one and see if that resolves the problem, or even run it that way long enough to recover the data.  If you do plan to do that and run it a long time, use masking tape to block the gap the cable goes through and the internal power supply fan outlet so the chassis fan properly draws air around the drives and motherboard.  If that works, then you can get more life from your NAS by replacing the internal supply with an SFX format one.
Message 46 of 53
Number6
I'm running the long tests on each disk now (on second right now). each takes 4 hours. After I run all six, THEN I'll try six spare drives to see what happens.
I don't think I have a spare PS (the only spare I had was already put into use).
Message 47 of 53
Sandshark
Sensei
If you can temporarily "borrow" an ATX supply from a working machine long enough to determine if the supply is the issue, that would help.  If that is it, we can guide you in replacing the internal one with a standard SFX one.  One issue may be the number of Molex 4-pin connections, as you need three.  But SATA to 4-pin adapters and 4-pin splitters can be employed.  Otherwise, it just needs the standard ATXv12 24-pin main and 4-pin CPU connections.  It should also be at least 450W to insure it has sufficient 12V power.
For data recovery only, if you have a way to mount the drives in a PC internnaly and/or externally using SATA to USB or eSATA connections, you can use R-Linux for Windows or a native Linux system to recover the data.  I'm not expert on that, but others can guide you.
Message 48 of 53
Guru
R-Linux for Windows is freeware, and won't work for this - it doesn't support RAID (so you can only use it for JBOD or RAID-1).
You could use their paid software (R-Studio) instead.  https://www.r-studio.com/data-recovery-software/
Message 49 of 53
Number6
Thanks very much to @Sandshark I was able to replace the entire box and ... it all worked just fine!!! Woo Hoo !!!!!!!
So, it *might* have been the PSU (or something else?).
Now that I have a ReadyNas Pro 6 that *might* just need a working PSU, I'd like to consider finding and trying to replace the PSU to see if I can get it working. It seems that I can find a power supply that will probably fit (kinda) or it might need a 24pin cable extender on ebay for about $30 --- or I see one there that's supposed to all fit right for $65. My experience over the years is that if something's not going to fit, I'll be the one that experiences it and ends up having trouble finding the right extra pieces.
Any specific suggestions (the cheaper the better) for a PSU that will "just fit" gladly accepted and appreciated.
Message 50 of 53
Top Contributors
Discussion stats
  • 52 replies
  • 3519 views
  • 0 kudos
  • 4 in conversation
Announcements
