× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
redynas 312
Damia
Guide
redynas 312
quick question which teaming mode (adapter bonding ) will be best to use for streming and file accessing wich dosnt need switch support
Model: ReadyNAS-3100|ReadyNAS-3100
Message 1 of 4
Accepted Solutions
Guru
Re: redynas 312
@Damia wrote:
I do have  a few users
What is the difference between ALB and TLB ?
TLB is transmit only, so it only applies to files downloaded from the NAS.  ALB works in both directions (and might be more tempermental).
Another option is to get a switch that supports LACP.
I don't think you'll see much gain with the RN300, so if you see problems simply revert back to a single ethernet connection.  These modes can be a bit like jumbo frames - sometimes they create more trouble than they are worth.
Message 4 of 4
All Replies
Guru
Re: redynas 312
The two best options are ALB and TLB.  In general these won't boost performance much unless you have several simultaneous users.  For most people using just one NIC interface is fine.
Message 2 of 4
Damia
Guide
Re: redynas 312
Message 3 of 4
Guru
Re: redynas 312
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 2810 views
  • 1 kudo
  • 2 in conversation
Announcements
