× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
rn42200 fails to boot
mgustus
I have a RN42200 with two brand new WD2002003FZEX drives installed. I am unable to gett them to initialize./fomat and I've tried to up date the OS too. In both cases the LED screen goes from Netgear Storage Welcome to a blank screen with a line in the upper left hand corner. I think  I have a dead box but thought I would post here to see if I've over looked anything. Thanks for your time.
Model: ReadyNAS-4200|ReadyNAS 4200
Message 1 of 10
Guru
Re: rn42200 fails to boot
Start by removing the disks and powering up.  Then see if RAIDar sees the NAS with a "no disks status".https://kb.netgear.com/20684/ReadyNAS-Downloads#raidar
Also, connect the disks to a windows PC (either with SATA or with a USB adapter/dock) and try testing them with Western Digital's Lifeguard utility.
If you are the original purchaser, you have 90 day phone support (via my.netgear.com).  Use that if you have it.
Message 2 of 10
mgustus
Thank you for the reply. Raidar doesnt see it with both disks removed.
Message 3 of 10
JohnCM_S
NETGEAR Employee Retired
Hi mgustus,
If RAIDar still cannot detect the NAS even if there are no disks inserted, there is a possibility that the chassis is faulty.If you are the original purchaser, you may contact our support for the warranty replacement.
JohnCM_S
NETGEAR Community Team
Message 4 of 10
Guru
I agree that contacting support is the next step - this is almost certainly a failed chassis.
Message 5 of 10
JohnCM_S
Hi mgustus,
We’d greatly appreciate hearing your feedback letting us know if the information that has been provided was able to resolve your issue or if you need further assistance.
If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
JohnCM_S
Message 6 of 10
mgustus
The replacement chassis has now failed. After running for several months, it fails to come up after a reboot. The menu just flashes. I pulled the disks with the same issue. I tried to recover the OS using a recovery USB and can not get it to boot. Looking in the back through the fins, I dont see any lights. I think its dead.
Model: ReadyNAS RND4220|ReadyNAS NV+
Message 7 of 10
Guru
I guess you'll need to contact support again.  Having a second chassis fail is unusual, I haven't seen that posted here before.
Message 8 of 10
mdgm-ntgr
Not all USB keys are compatible, but it does sound like you may have encountered another hardware failure. This is unusual.
Message 9 of 10
mgustus
Thanks for the reply. I used the same USB before. Yeah seems odd. Murphy has been hanging out on this NAS since I got it.
Message 10 of 10
Top Contributors
Discussion stats
  • 9 replies
  • 1372 views
  • 0 kudos
  • 4 in conversation
Announcements
