× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
snapshot volume useage not showing in gui
ahellary1
Follower
for some time even before the last 2 os upgrades the volume usage of the snashots is not visable in the gui (ie the yellow usage bar) ready nas 316 im not sure if this will effect the backups as it will be trying to back up more than needed ... also its just  dam annoying i dont have this problem with 2 214 s and a 4312  is there a way to solve this as support say they want me to pay for this to be sorted and as the unit is under 12 months old im not happy to say the least
Model: RN31600|ReadyNAS 300 Series 6- Bay
Message 1 of 2
cs_giuseppe
Apprentice
Re: snapshot volume useage not showing in gui
Hi,
at the volume level Quota is enabled?
if not, then enable and wait .... then see if there is the information
if is enabled then disable quota, reboot the unit, wait a day and re-enable quota.
If possible install fw 6.7.5 if your is older
Giuseppe
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 2226 views
  • 0 kudos
  • 2 in conversation
Announcements
