× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
volume amount on 628x
drivethebus
Hi,
Im confused as to why my storage ammount doesn't seem match my drives.
using xraid and have 7 drives installed: (6)- 10tb ironwolf pro, (1) - 12 tb ironwolf pro.
system is showing tht my total = 45.46 tb.
Does this look right?
Model: RN628X|ReadyNAS 628X - Ultimate Performance Business Data Storage - 8-Bay
Message 1 of 4
Accepted Solutions
Retired_Member
Not applicable
Re: volume amount on 628x
Hi @drivethebus,
6x10 and 1x12 TB gives in xraid (which is raid6 in your case) 45.4 TB, which exactly is what you observe.
You might want to use the Netgear RAID Calculator to verify.
Please go here http://rdconfigurator.netgear.com/raid/index.html
Message 2 of 4
All Replies
Retired_Member
Not applicable
Hi @drivethebus,
Message 2 of 4
Guru
@Retired_Member confirmed the size for you - I'd like to add that you aren't able to use all of the 12 TB drive.  To do that, you'd need 4 of them in the array (because it is dual redundancy).
Message 3 of 4
drivethebus
thanks for the answer.  Just what I was looking for.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 1036 views
  • 3 kudos
  • 3 in conversation
Announcements
