- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
volume degraded after disk swap on a RN312
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi there,
I run a RN312 with two 6TB western digital red drives runing x-raid. one of them started having an increasing reallocated sector count, so I replaced it with another drive of the same type.
so far so good. after re-syncing had been completed the volume is now degraded. rebooting the RN triggers a new re-sync with the same result - a degraded volume. mdstat.log claims I have two working devices (drives), one active and one spare.
is there any way to recover from this outside of a factory reset (there is a backup, however on the other end of a very slow connection, so I'd rather not have to restore)...
thanks for any pointers...
best,
Lorenz
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
that's right, I did replace it with one of the same type and size...
I did a factory reset and the volume ist healthy again now, "just" need to restore the back up after updating the ssh setup with the newly generated keys....ah well....
thanks for thinking along sandshark & stephenB!
best,
Lorenz
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: volume degraded after disk swap on a RN312
You might try removing the spare and then confirming that you still have access to your data.
Then unformat the spare with Western Digital's lifeguard program in a Windows PC. The quick "write zeros" test will do that nicely.
After that hot-insert that drive into the NAS, and it should re-add it to the array (hopefully not as a spare this time).
- Mark as New
- Bookmark
- Subscribe
- Permalink
thanks a lot for the ideas stephen! I did as you suggested: data was still there after removing the new disk that was only recognized as spare. re-wrote it will all zeros. powered down the RN, reinserted the wiped disk, powered it up again, it synced: same result - volume is still degraded..:-(
on the up side I now have a hard drive docking station to wipe and re-use my old drives..;-)...
I just realized I did deviate from your suggestion in one point: I did not hot-insert the wiped drive as that did not work the 1st time. could that make a difference? if not: any other ideas?
thanks & best,
lorenz
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hot-insertion is better because the NAS detects the insertion. If you insert with the NAS powered down, it needs to figure out that an insertion was done.
The net here though is that the NAS is insisting on marking the drive as a spare. One thing you could try (painful) is to do a factory reset with both drives in place. After a successful RAID sync you'd have to restore the data from backup.
You could also try paid support via my.netgear.com.
- Mark as New
- Bookmark
- Subscribe
- Permalink
hot insertion did not help either. will backup my config and try moving from x-raid to flex-raid and report back if that makes the RN include the 2nd disk again. if I do not report back on this thread again, I will have resorted to going back to factory settings...:-/
thanks for attempting to help!
cheers,
lorenz
- Mark as New
- Bookmark
- Subscribe
- Permalink
I believe you should be able to change to FlexRAID and manually add the drive to your array with the "expand" option, then move back to XRAID once it's complete. You may have to re-format the drive first (in the NAS).
- Mark as New
- Bookmark
- Subscribe
- Permalink
thanks, that was my idea as well, however when moving to flexraid the volume is shown as raid 1, however still degraded. I can thus not proceed as planned / as suggested.
also any reboot results in a re-sync of the 2nd drive, regardless wether in X-Raid or flexraid, but always with the same result - a degraded volume.
overall this might be a bug in the drive detection / raid software as it originally occured after hot swapping the failing drive for a new one. will likely restore factory settings over the weekend...
- Mark as New
- Bookmark
- Subscribe
- Permalink
Though you said you replaced the drive with another one of the same type, one thing that will cause that is if the new drive is too small.
- Mark as New
- Bookmark
- Subscribe
- Permalink
best,
Lorenz
