× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
volume expansion on ready NAS ultra
LucDV
I have on my Ready NAS ultra 6 bay with 3 HD's of 2TB (initial install). They were installed in X-raid.
Afterwards, I installed 3 extra volumes of 4 TB at different timings, the last one a few days ago.
This last install didn't increased the available volume and overall volume is still limited at 9255GB while global volume of installed HD's is 18TB.
I read the overall volume is limited at 14 TB. Is this correct? In this case, can I simply remove two 2 TB disks? Are there other alternatives to obtain a maximum usable storage capacity?
A factory reset seems no solution for me since I have no possibility to first back-up alle data.
Thanks for helping me out with this topic.
Kind regards
Message 1 of 16
vandermerwe
Master
Re: volume expansion on ready NAS ultra
There are 2 limits:
1. An 8TiB expansion limit from the volume size at last factory default. In your case the original volume was about 3.6TiB, meaning you could expand to 11.6 TiB before hitting the limit, which is what has happened to you when you put in the 3rd 4 TB disk.
2. A 16TiB volume size limit - which can be overcome with a factory default with a volume size > 16 TiB in place.
Both limits can be overcome with a factory default. You would need to backup all of the data on your volume,factory default, then restore the data.
You cannot just remove 2 of the 2tb disks.
I'm afraid you are going to have to factory default.
You should have a backup of the data anyway.
Message 2 of 16
LucDV
Thanks for this feedback.
Since I placed initially 3 HD's of 2TB, I suppose te volume is about 5,4TB and not 3,6TB?
Can I withdraw without any risk or loss of data the last 4TB disk I installed?
Message 3 of 16
Guru
3x2TB Raid 5 has 4 TB volume size = about 3.6 TiB.
Message 4 of 16
vandermerwe
Master
I don't know if you can just remove the most recently added 4 tb disk, what does the volume page say in Frontview?
Are 6 disks listed as active and part of the array?
Message 5 of 16
mdgm-ntgr
NETGEAR Employee Retired
If you remove a disk you would have a non-redundant volume.
Backup, factory default (wipes all data, settings, everything) and restore data from backup is the way to go here.
Message 6 of 16
LucDV
OK, I understand I have 3,6TB + maximum extension of 8TB.
But, I have in frontview 3 disks with available volume of 1858GB en 3 disks of 3721GB. Global indicated storage capacity is 9255GB. All 6 disks are indicated as active.
This was already the storage capacity before I installed the last disk of 4TB.
I understand I should have at least a capacity of 3,6TB + 8TB = 11,6TB.
Where did it go wrong and how can I still fix that?
I don't have the capacity of making a full back up but if I could be able to expand my available till 11,6 TB, I would be grateful 😉
Message 7 of 16
mdgm-ntgr
If expansion would take you past the limit it won't take place at all.
Message 8 of 16
LucDV
but i don't pass the limit of 11,6TB, i only have an available of 9255GB
Message 9 of 16
mdgm-ntgr
But if expansion woukd tie you past the limit it won't expand at all.
Message 10 of 16
LucDV
OK, but initially I had 3,6TB (3HD's of 2TB). I installed a HD of 4TB, available became 7,6TB (+-). Later, I installed a second 4TB HD. Available should have been then 11,6 TB which is the maximum possible. Why then I still have an available of only 9,225TB. Sorry for insisting, but I want to understand completely the issue.
Message 11 of 16
mdgm-ntgr
But you said you added three 4TB disks?
Have you tried a reboot?
I think adding a third 4TB disk has limited what expansion you can get.
Message 12 of 16
LucDV
Yes, I've done a reboot. All 6 disks are allocated for 1858GB(2TB disks) and 3721GB (4TB disks). Global allocated stayed unchanged on 9255GB.
It seems to me that after installation of the 5th disk a volume of 11,2 TB should have been available, which was not (then also 9225TB)
I installed 3 4TB disks at different timings (months).So, after installation of the second 4 TB disk, my available should have been 11,2 TB. Which was not (9,225TB)
Message 13 of 16
vandermerwe
Master
I'll just repeat what mdgm has already said several times. The 9.2 TiB is the correct capacity after the 2nd 4 tb disk was added.
When you add the 3rd 4tb disk the volume size is theoretically 12.8 TiB which takes you over the 8TiB limit. NO expansion takes place because of this. The Nas can't partially expand to the 11.6 limit.
You will need to factory default.
See http://ram.kossboss.com/xraid/
Message 14 of 16
LucDV
OK.
Other question. Can I safely replace the three 4TB's disks then by 2TB's disks, one at the time. Must I do the replacement with power off? (In this case, I can use the 4TB disks for back-up before going to a factory default)
Message 15 of 16
mdgm-ntgr
To revert to smaller capacity disks a factory default would be needed.
Message 16 of 16
Top Contributors
Discussion stats
  • 15 replies
  • 2380 views
  • 0 kudos
  • 4 in conversation
Announcements
