× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
which is the easiest way to have a wakeonlan button?
carlocki
Luminary
I need a ready made, fast and simple button for wake on lan
any suggestion?
Model: RN10443D|ReadyNAS 100 Series 4- Bay (4x 3TB Desktop)
Message 1 of 6
Accepted Solutions
Guru
Re: which is the easiest way to have a wakeonlan button?
I use wakemeonlan from http://www.nirsoft.net/utils/wake_on_lan.html
You could set up a windows button to wake up a specific machine using the command line option (Turn On a Computer From Command-Line section).  Though I haven't tried that.
Message 2 of 6
All Replies
Guru
Message 2 of 6
carlocki
Luminary
works so well
where you put the folder of the program?
Message 3 of 6
Guru
It's not installed, so it really doesn't matter.  You could just put it in the root of the C drive.
Message 4 of 6
carlocki
Luminary
it really works, thank you
where i can read a tutorial to do a personalized windows 10 installation?
Message 5 of 6
Guru
The only info I have is in the link I posted above.
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 1323 views
  • 2 kudos
  • 2 in conversation
Announcements
