- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Admin page issue after upgrade
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have 2 and 4 bay NAS drives. I upgraded from 6.9.2 arm to 6.9.3 arm. Upgrade proceeded normally. After reboot the splash screen indicated 6.9.3 and then "Connection to ReadyNAD Admin Page". The indicator completes, back to the splash screen and repeats the "Connection to..." page. This will continue repeatedly with no end. The drive can be accessed and perform normally, but you can not get to the Admin page as it keeps resetting the page. ALL of my drives that were upgraded re doing the same thing. I have rebooted and powered down, cleared browser cache, use Firefox and tried IE as well. All with the same result.
Anyone have any ideas to clear this Admin page issue ?
Paul
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Admin page issue after upgrade
Sorry for the inconvenience, engineer will contact you to help check the issue.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Could you please clear the browser's cache and cookies and launch the admin UI again?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello tec-man
can you download system logs from Raidar and send it to nsbu_logs@netgear.com?I want to take a look middleware logs to determine the issue.
https://www.downloads.netgear.com/files/GDC/READYNAS-COMMON/RAIDar_6.3.0.exe
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for sending the logs. As you're having problems with this on multiple units can you send the logs from all of the units displaying these symptoms on 6.9.3 not just one. The problem you're facing may/may not be the same on all units. If it is the same having logs from different units may still help with identifying the root cause.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Problem solved.
(Moderator) Bryan followed up with me. Using device logs and then remoting in he was able to solve the problem.
Great support from Netgear on the issue.
paul
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi,
I have the same issue. What was the solution?
Thanks
//Magnus
- Mark as New
- Bookmark
- Subscribe
- Permalink
Can you download your logs using RAIDar as well and send those in please?
- Mark as New
- Bookmark
- Subscribe
- Permalink
OK, I will be onsite Thursday next week.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I do not know what was done. Bryan remoted in and must have made changes to code or parameters.
paul
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
It was indicated that the fix will be in the next update 6.9.4
paul
- Mark as New
- Bookmark
- Subscribe
- Permalink
That's no good solution, because my NAS can't be updated anymore, neither by USB-recovery nor by https://Readynas IP/fwbroker (Forbidden, You don't have permission to access /fwbroker on this server).
I hope there is another solution.
Rolf
- Mark as New
- Bookmark
- Subscribe
- Permalink
If you have a scratch disk, can you try
- zeroing the scratch disk
- powering down
- removing current disks (labeling by slot)
- installing the scratch disk by itself
- powering up the NAS
The NAS should do a factory install on the scratch disk. It'd be useful to know what firmware it installs.
USB recovery generally is only needed for specialized situations- usually it's not something to try first. The error message on fwbroker is unusual. Is your browser set to automatically apply credentials when you access the NAS?
You will get an error if you use http://Readynas IP/fwbroker, but not that one. Still it might be helpful to double-check that you are using https.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello StephenB,
thank you for your reply.
I'll do this next week, because now I'm in weekend and have no acces to the NAS.
I'm quite sure it will be the 6.9.3 cause Slas has already checked the Log-files.
He found the following errors:
Mar 07 13:07:58 NAS-316 kernel: traps: readynasd[14708] general protection ip:7f8340bcd19a sp:7f8307ffe060 error:0 in libc-2.19.so[7f8340b54000+1a1000]
Mar 07 13:09:50 NAS-316 kernel: traps: readynasd[18104] general protection ip:7f0c84ca919a sp:7f0c62ffc060 error:0 in libc-2.19.so[7f0c84c30000+1a1000]
Mar 07 13:16:58 NAS-316 kernel: traps: readynasd[25014] general protection ip:7fde3305319a sp:7fde117f9060 error:0 in libc-2.19.so[7fde32fda000+1a1000]
Mar 07 13:22:53 NAS-316 kernel: traps: readynasd[3617] general protection ip:7f166865019a sp:7f16367fb060 error:0 in libc-2.19.so[7f16685d7000+1a1000]
My browser should automatically apply credentials. I even have installed the certificate, that the NAS created.
I tried both, http and https. Both had the same error. It's strange cause anything else on this NAS works very well, i can see all data in explorer and can write in directorys even the NAS is doing it's recovery job. I only can't access the main page.
I'll try your advice next week.
Thank you.
Rolf
- Mark as New
- Bookmark
- Subscribe
- Permalink
That's a very different error to what the logs for tec-man's system showed so your problem is likely different. There weren't general protection faults in his logs.
You're welcome to send us your logs too if you like (see the instructions for sending the zip file - I presume you downloaded it using RAIDar - in the Sending Logs link in my sig).
- Mark as New
- Bookmark
- Subscribe
- Permalink
I too am experiencing the admin page issue. I am uploading logs to you shortly. Hope this helps. Thank you.
edit: the admin page worked for a little while after a few reloads, I was happy for a few moments but then it started reloading again after clicking through a few items.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Betreff: Admin page issue after upgrade
I have the same problem. After rebooting the volume is inactive and so all shares are not reachable anymore.
I tried disk-check via boot-menu and afterwards I could at least reach the admin-page again. But it shows now that volume is inactive and volume-usage is at 100%. What can I do?
Juergen
- Mark as New
- Bookmark
- Subscribe
- Permalink
Betreff: Admin page issue after upgrade (RN2120v4, volume now at 100%)
Juergen
ReadyNAS2120v2 with 4x 4TB
- Mark as New
- Bookmark
- Subscribe
- Permalink
You can send your logs in if you like (see the Sending Logs link in my sig).
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have a backup on my old RN2100, but because that one has smaller HDUs, not of all shares. I have a backup of only the most important data.
As I do backups of my MacOS-clients also on USB-HDUs I could live with loosing the share "Backup" on my 2120, bu therefore recover the rest, if possible in any way.
- Mark as New
- Bookmark
- Subscribe
- Permalink
In that case you should contact support.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi,
I have sent the logs now.
//Magnus
- Mark as New
- Bookmark
- Subscribe
- Permalink
I've sent you a suggestion to try.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I am having the same issue after upgrading to 6.9.3
- Admin page does not load
- Cant download logs from RAIDar
- FWbroker says i dont have permissions to access...
Really dissapointing for a NAS.
