- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Admin page issue after upgrade
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Admin page issue after upgrade
Have you tried clearing your web browser cache, closing your web browser and then reopening the web admin interface?
Have you tried a different web browser?
Can you connect your NAS to the internet it, reboot it and wait about 10 minutes?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi! Thanks for your answer.
Finally i downgraded the version to 6.9.1 and i factory reseted it. Access looks ok now, however this happens when I join the AD domain (pretty huge one):
- SMB shares become unaccesible, cant even \\xx.xx.xx.xx the NAS. Can ping it and admin it though.
- Overall performance drops, got kicked out from the admin page constantly.
Any idea?
BR
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hey Deniro,
I too have this admin refresh issue.
I'm pulling the logs now and uploading them if I could kindly ask for someone to take a look and help fix this with me.
Cheers,
Seb
- Mark as New
- Bookmark
- Subscribe
- Permalink
thebassy hae you tried clearing your web browser cache, closing your web browser and reopening the web admin interface?
- Mark as New
- Bookmark
- Subscribe
- Permalink
The interesting thing is I've had both interfaces in a bond for Adaptive Load Balancing with eth0 as the primary. On one of the reboots of the system due to the putname+64 error, the interfaces were removed from the bond. Now the admin page is only accessible via eth1. It's like eth0 doesn't work and when I attempt a new bond it fails.
Not sure if this is related or not but this is where I'm at now.
Thanks for the reply 😊
- Mark as New
- Bookmark
- Subscribe
- Permalink
after update to 6.9.3 cannot load admin page MAC osx 10.13.4
attached log
- Mark as New
- Bookmark
- Subscribe
- Permalink
Upgraded to 6.9.3 and now I'm having a reloading admin page.
I've send in the logs by mail. I could really use some help on this! 🙂
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'm having the same issue with the admin issue after the latest upgrade. Clearing the browsing history cache and reopening it worked well for a while, but the problem quickly came back. When will the revised firmware become available?
- Mark as New
- Bookmark
- Subscribe
- Permalink
DGM01 can you send in a fresh set of logs please? You can download the logs using RAIDar and then send them in (see the Sending Logs link in my sig).
- Mark as New
- Bookmark
- Subscribe
- Permalink
DGM01 it looks like you've got other problems going on in your case. I've sent you a PM.
- Mark as New
- Bookmark
- Subscribe
- Permalink
DGM01 the users group doesn't exist on your NAS, but instead a different user has the group id 100 on your NAS. That would be at the very least contributing to why you can't access the web admin page.
Jun 05 08:38:57 readynasd[11599]: Default group users does not exist. (Check /etc/frontview/account.conf). Continue importing.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have exactly the same problem. How do i send you my logs?
I hope you can help me out. This is unworkable at the moment.
Best regards,
PDAHazzard
- Mark as New
- Bookmark
- Subscribe
- Permalink
PDAHazzard you did an unsupported upgrade direct from 6.2.2 to 6.9.3.
You set a static I.P. address but didn't specify DNS Server Addresses.
You could try an OS Re-install or as you've got SSH enabled you could try:
# cd /apps/.freeapps # rm -r wordpress/
If you still can't access the web admin page after that you could also try clearing your web browser cache, closing your web browser and then reopening the web admin page
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
suno is your NAS behind a corporate firewall/proxy?
It can't connect to the internet to address the problem.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Should I connect to internet?
- Mark as New
- Bookmark
- Subscribe
- Permalink
@suno wrote:
Yes it is within our firewall
Netgear does push hot-fixes, so it would be best to enable the NAS for internet access. That also makes it more convenient to do updates, and allows you to use NTP.
IMO it should still be behind a firewall though, and there normally is no reason to allow unsolicited inbound traffic.
- Mark as New
- Bookmark
- Subscribe
- Permalink
The only other ways to address the issue you're seeing would involve shell commands or putting a different firmware e.g. 6.9.2 or 6.9.4 beta on the NAS unit using USB Boot Recovery. Note that units updated to 6.9.x firmware should not be downgraded to firmware older than 6.9.0.
- Mark as New
- Bookmark
- Subscribe
- Permalink
In 6.9.3 (readynas 3138) it intermittently works but after upgrading to 6.9.4 the admin portal no longer loads. Can somebody assist or provide a solution? I am still able to access the files by windows explorer; just no longer can access the admin portal page.
- Mark as New
- Bookmark
- Subscribe
- Permalink
While Googling "readynas 104 admin page randomly failing", it would appear that I am not alone. 😞
Should I take a gamble and load the 6.10.x beta FW or have someone officiall take a look at the logs?
Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
In case it helps anyone else, the problem I had was due to the a previoius login that had persisted. Once I forced a logout, it was back to normal.
- Mark as New
- Bookmark
- Subscribe
- Permalink
How did you force the logout and where please
- Mark as New
- Bookmark
- Subscribe
- Permalink
If you still see your "admin" user in the upper right, and you can still get to it, then you can logout. I've enabled SSH so I can fix/manage some of this stuff easier w/o having to trely on the web GUI.
I think this issue may be more complicated though. I think there may be some secondary issues occuring with Chrome and how it is handling the SSL certificate as "invalid", which it kinda is. (SSL is only valid when used on a FQDN, not an IP address).
- Mark as New
- Bookmark
- Subscribe
- Permalink
@KingOfPain wrote:
I think this issue may be more complicated though. I think there may be some secondary issues occuring with Chrome and how it is handling the SSL certificate ....
Loss of access to the admin page shouldn't be related to certs (though if you haven't installed a CA cert you will need to click-through security warnings in most browsers).
