× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
Bad Drive Replaced, Not Resyncing
erynhopekb
Follower
I have a four drive ReadyNAS in a RAID5 array. I replaced a failing hard drive this morning but the array is not resyncing. It's using xraid and firmware 6.1.9, drives 1,3, & 4 are blue and drive 2 (new one) is gray. I don't know what other information would be useful, but if anyone has a suggestion, I'll try it. Thanks.
Message 1 of 13
Guru
Re: Bad Drive Replaced, Not Resyncing
What model drive did you remove (and what model was the replacement)?
FWIW, 6.1.9 is very old.  After you get past this you should upgrade it.  However, don't mess with that now.
Message 2 of 13
vandermerwe
Master
Also:
What model Readynas is this?
Did you have the nas on when you removed the old drive and inserted the new drive?
Was the new drive tested before you put it in?
Do you have a backup?
Message 3 of 13
S_Lee
Similar situation
RN2120 - 4 Drives - 4TB each (same make/model)
Firmware - 6.2.4
RAID5
Drive 1 went bad and got a RMA replacement, same make/model.
Tech installed the new drive on Friday (Sept 04) and today (Tues 09-08) it still shows as RED.  Log file does not show any info that it even attempted to resynch.
Had tech remove new drive 1 and re-seat it again.  status has not changed.
According to this procedure http://kb.netgear.com/app/answers/detail/a_id/23456 - RN2120 is completely hot swappable and does not require any input from the user or reboot.
Please advise.
Message 4 of 13
Guru
What model drives are you using?
You are correct, the unit supports hot-swapping.  You can use the support "live chat" option, support can likely figure out the issue faster than the forum.
Message 5 of 13
S_Lee
Western Digital
4.0 TB
WD4000FYYZ-01UL1B0
Message 6 of 13
S_Lee
I guess it could be possible that the replacement drive I received is defective too.  It is a refurbished unit according to the receiving slip.
How can we test the replacement drive?  Can my tech could pull the replacement drive and connect it to a PC to see if it detects the drive?
Message 7 of 13
Guru
I think support is a good next stop.
They will want a full log download, so you might as well do that now.
Message 8 of 13
vandermerwe
Master
Yes you can do this and use WD lifeguard to test the drive thoroughly.
Is there a backup?
Have you attempted at least one reboot?
Message 9 of 13
S_Lee
I will have my tech pull the drive out again and use the WD Lifeguard to test it tomorrow morning (he's already gone for the day).
No we have not rebooted the ReadyNAS yet.
Message 10 of 13
vandermerwe
Master
Is there a backup?
i would reboot it once before moving on to the drive test.  When you do the drive test, use the extended test.
Message 11 of 13
Guru
I agree a reboot is good idea.
Often removing and then reinserting the drive works as well.
I believe the NAS uses the SMART self-test, so make sure that one is run (its also the shortest).
Message 12 of 13
S_Lee
Ran diagnostics using Western Digital Lifeguard - Bad Sectors detected.
Replacement Drive is DOA.
Will contact Support and get another replacement RMA.  Hopefully the next one will work.
Message 13 of 13
Top Contributors
Discussion stats
  • 12 replies
  • 3234 views
  • 0 kudos
  • 4 in conversation
Announcements
