× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
Balance - 1% for hours
Shorey
I started balancing, but it seems to have corrupted my drive. After rebooting it just hangs at Balancing Data 1% for hours. Is there anything I can do to cancel it?
Message 1 of 7
cpu8088
Virtuoso
Re: Balance - 1% for hours
which model?
which firmware?
Message 2 of 7
Mr_HoneyDo
I'm having the same issue, just stuck at 16% not 1.  Just upgraded to OS 6.4 and attempted a balance on my RN516.  No activity on the drives either.
Message 3 of 7
Guru
Do you have spindown enabled?  If so, maybe disable for a while.
Message 4 of 7
Shorey
RN314
V6.4
Message 5 of 7
Shorey
Disk spindown is enabled (after 45 mins); but I can't disable it as I can't access the admin page...even RAIDar doesn't see the drive.
Message 6 of 7
Shorey
I've found that if I force shutdown the RN by holding down the power button (don't like doing this but have no option) and then reboot; there is a small window of about two minutes after it has booted up again (is taking a very long time to boot, >10 minutes) when I can access the admin page before the drive crashes again and I lose access. If I go to the System>Volumes page in that time I see the message "Balancing in progress. 0% complete".
What can I do in that small window of access to disable the disk balancing?
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 2410 views
  • 0 kudos
  • 4 in conversation
Announcements
