- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Corrupt Boot - "Err: Could not mount root RAID d"
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello,
i bought this NAS Box from ebay!. but i don't know how to set it up ? When I installed 1 or 4 disks , the LCD showed the error: "Err: Could not mount root RAID d" ..!
Can you tell me how to fix it, I tried to Boot --> Factory Default. but it still happen !!!
Thank you very much !!!
Jimmy.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
For most users, the best RAID format is to use the default XRAID. That can be expanded w/o data loss, and it has protection for a single disk failure.
If you want maximize storage space and don't care about expansion or protection from a disk failure, then the best option for that is to use flexraid and create one volume for each disk.
To do that, you need to start over and set up the NAS again. Remove all disks but the first, then do a factory reset using the boot menu. You have a 10 minute window to configure the system for flexraid using RAIDar.
Details are in the hardware and software manuals for your ReadyNAS here: http://downloadcenter.netgear.com/en/product/RNDP4000%20(ReadyNAS%20Pro%204)#searchResults
@JimmyChen wrote:
?. Just put in & read the data inside (with NTFS format).
Your NAS doesn't use NTFS. It uses EXT. When you insert a disk into the NAS, the data on it will be wiped.
The NAS doesn't let you create a "library" of hard drives that you can insert/remove on demand. The disks need to remain in place after you create the volumes.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Corrupt Boot - "Err: Could not mount root RAID d"
Buying a second hand unit is risky and also the warranty and support is for the original purchaser from an authorised reseller only.
Which model is this?
You possibly could try USB Boot Recovery
- Mark as New
- Bookmark
- Subscribe
- Permalink
Name:_______Jimmy_____________ Date:_______14/01/2017__________
The debugmode number is: 50410
Thanks for your quickly reply !!!
Jimmy.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Which model and which firmware?
I understand you now have reset it successfully but don't like it that it has created a single volume C using all your disks?
- Mark as New
- Bookmark
- Subscribe
- Permalink
my NAS is: ReadyNAS Pro 4 : RNDP4000 - Model : RND-4A
Firmware Current: 4.2.30
Yeah! Correct ! it has created a single volume C using all to 1 disks. But I want It separate 1-2-3-4 .
many thanks for your helping !
- Mark as New
- Bookmark
- Subscribe
- Permalink
and ... Please give me a suggestion of RAID Setting !
because I just only want to make a big storage with 4 hard drives ( has data inside ready ) , Like plug & play & when i put in a hard drive ( with data inside ) I don't want it Resync or Format it whatever ?. Just put in & read the data inside (with NTFS format).
can i do that with Flex-RAID-0 ?
Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
