Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
CrashPlan Fatal Java error after update to OS 6.6.1
- Mark as New
- Bookmark
- Subscribe
- Permalink
2017-01-18
02:29 PM
2017-01-18
02:29 PM
I upgraded OS yesterday and now CrashPlan is crashing.
# A fatal error has been detected by the Java Runtime Environment: # # SIGBUS (0x7) at pc=0x00007fa30bd09460, pid=26003, tid=140338276411136 # # JRE version: Java(TM) SE Runtime Environment (8.0_72-b15) (build 1.8.0_72-b15) # Java VM: Java HotSpot(TM) 64-Bit Server VM (25.72-b15 mixed mode linux-amd64 compressed oops) # Problematic frame: # V [libjvm.so+0x70c460] jvm_define_class_common(JNIEnv_*, char const*, _jobject*, signed char const*, int, _jobject*, char const*, unsigned char, Thread*)+0x100 # # Core dump written. Default location: /usr/local/crashplan/core or core.26003
If I manually start it from the CLI and then check status:
root@NAS:/usr/local/crashplan/bin# ./CrashPlanEngine start Starting CrashPlan Engine ... Using standard startup OK root@NAS:/usr/local/crashplan/bin# ./CrashPlanEngine status CrashPlan Engine (pid 30330) is running. root@NAS:/usr/local/crashplan/bin# ./CrashPlanEngine status ./CrashPlanEngine: line 116: cannot create temp file for here-document: No space left on device CrashPlan Engine is stopped.
root@NAS:/usr/local/crashplan/bin# df -h
Filesystem Size Used Avail Use% Mounted on
udev 10M 4.0K 10M 1% /dev
/dev/md0 4.0G 1.6G 2.2G 42% /
tmpfs 2.0G 0 2.0G 0% /dev/shm
tmpfs 2.0G 6.0M 2.0G 1% /run
tmpfs 986M 2.7M 984M 1% /run/lock
tmpfs 2.0G 0 2.0G 0% /sys/fs/cgroup
/dev/md127 11T 5.6T 5.4T 52% /data
/dev/md127 11T 5.6T 5.4T 52% /home
/dev/md127 11T 5.6T 5.4T 52% /apps
Any ideas?
Solved! Go to Solution.
Message 1 of 3
Labels:
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
2017-03-23
07:05 AM
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
2017-03-23
07:05 AM
Retired_Member
Not applicable
- Mark as New
- Bookmark
- Subscribe
- Permalink
2017-03-23
09:19 AM
2017-03-23
09:19 AM
Re: CrashPlan Fatal Java error after update to OS 6.6.1
Antivirus as the root cause for another non-obvious issue. I'm very much looking forward to 6.7.
Message 3 of 3
