Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
DUO Upgrade 4.1.7 - Alerts and Update Fail - Case #16293776
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-07-28
02:50 PM
2011-07-28
02:50 PM
Since upgrading to 4.1.7 on my ReadyNAS DUO i find -
- alerts do not work any longer and give error - Unable to contact SMTP server - i have checked the settings and they are the same as working in Outlook
- Update button gives error - Error Connecting to remote server
Is there a fix yet for these issues? Both worked previously.
Thanks Jim
Thanks Jim
Message 1 of 4
Labels:
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-07-28
07:58 PM
2011-07-28
07:58 PM
Re: DUO Upgrade 4.1.7 - Alerts and Update Fail
When I set mine up, it was done in 4.1.6 which did not have the preconfigured Gmail addressing as the x-86 version of Frontview did. I kept trying to use my primary e-mail as the sender but it would never work as that service is not my IP provider. I had to use my log on and password of the e-mail account provided by my IP provider but the address was my primary e-mail account. The only change after upgrade to 4.1.7 is that in the pull down menu for e-mail provider, it shows custom. I don't recall that pull down in 4.1.6.
It should not have changed simply by a firmware upgrade. Is it possible that the password has changed?
Message 2 of 4
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-07-29
09:05 AM
2011-07-29
09:05 AM
I had my alerts setup to use my gmail account details previously, obviously not my IP provider. Now I have tried many options available - gmail and custom (with my IP details) - not sure what Internal provides or how to use it and I do not have AOL.
But both give the same error - Unable to contact SMTP server. Also using the Update button gives error - Error Connecting to remote server
Both worked before in 4.1.6
Message 3 of 4
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-07-29
08:11 PM
2011-07-29
08:11 PM
I would suggest you open an online ticket with tech support. It is possible that the upgrade to 4.1.7 encountered a glitch during the download. Once you have the case #, edit your first post and add the case # to the subject line.
Message 4 of 4
