- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Disc Usage Warning
- Mark as New
- Bookmark
- Subscribe
- Permalink
Disc Usage Warning
After updating firmware to 6.6.1 i keep getting a Disc Usage Warning
I varies between 10-30% left open. However, when looking at the admin page, data usage says 2.39TB free of 2.71TB. Currently I do have an external 1TB drive that the NAS backs up to. It is showing 554.62GB free of 916.77GB.
Any thoughts
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Disc Usage Warning
Can you send in your logs (see the Sending Logs link in my sig)?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I started getting the same exact warning this evening. My email notification reads as follows:
"Less than 5% of volume media's capacity is free. Performance on volume media is degraded. To improve performance, you must add capacity."
I got warning progressively from 30%, 10% and then this one.
Only about 15% of the disk is actually full - about 1.6T of 1.8T are actually free.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
And mdgm, I know you asked the OP for logs - I thought I'd list what I see as well just in case its helpful.
Here goes a snip of the logs: Thank you so much.
Thu Jan 19 2017 19:47:22 | Volume: Less than 5% of volume media's capacity is free. Performance on volume media is degraded. To improve performance, you must add capacity. | |
Thu Jan 19 2017 19:37:59 | Volume: Less than 10% of volume media's capacity is free. Performance on volume media is degraded. To improve performance, you must add capacity. | |
Thu Jan 19 2017 19:17:36 | Volume: Less than 20% of volume media's capacity is free. Performance on volume media will degrade if additional capacity is consumed. NETGEAR recommends that you add capacity to avoid performance degradation. | |
Thu Jan 19 2017 18:57:11 | Volume: Less than 30% of volume media's capacity is free. NETGEAR recommends that you add capacity to maintain current performance levels. Continuous protection snapshots will be deleted when volume free space is less than 5%. |
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Can you disable anti-virus, reboot your NAS, wait say 10 minutes or so and then re-enable anti-virus and see if it is any better?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have seen the same messages on my ReadyNAS214 and 102. Lots of space left on the drives. I have 7 ReadyNAS units in our enterprise, and all but one have been updated to the new 6.6.1 OS. These are the only 2 units I am getting the errors on.
- Mark as New
- Bookmark
- Subscribe
- Permalink
First thing this morning
Disabled Anti-Virus
Reboot NAS
approx 30 min later enabled Anti-Virus
It has been about 4 hours and have not recieved any
warnings on disc usage.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Funnily enough, the messages seem to have subsided on their own when I rebooted a couple of days back. I just did this again:
reboot
turn on Antivirus after 20minutes
- Mark as New
- Bookmark
- Subscribe
- Permalink
Just did this with my ReadyNAS102. We will see what transpires.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Nope, still the same issue on my ReadyNAS 102. I disabeld antivirus, rebooted, waited 20 minutes, then enabled anti virus. One thing I have found with the 6.6.1 update, is the virus scanning can't be configured. Meaning there aren't any options any more.
My ReadyNAS214 was reporting low disk volume (less than 30% remaining) on a 4TB RAID 5 configuration. Used 29.3 GB out of 2.69 TB. I think the 6.6.1 update borked a few things.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Still have the same issue
@ 0759 today I received a message of 30% free
@ 0800 today I received a message of 20% free
@ 0818 today i received a message of 10% free
I disabled AV
rebooted
enabled AV after 30
it does seem firmware update broke a few things
Actual disc usage to date: 2.3TB free of 2.71
- Mark as New
- Bookmark
- Subscribe
- Permalink
If you leave AV off for a longer time, does the problem stop when AV is off?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I will let you know. Odd thing is, this isn't happening to ALL of my ReadyNAS's that are up to date with 6.6.1. Just 2 of them. RN102 is using a JBOD (1TB) and my 214 is using 4 x 1TB drives in a RAID 5 configuration. No reason why I would get a low disk notification.
- Mark as New
- Bookmark
- Subscribe
- Permalink
As an update, I left the virus scanner OFF and did not get the warning about disk capacity. Regardles, I shouldn't have to modify my ReadyNAS settings. NetGear need to investigate the issue and release a patch. The least they can do is return control of the antivirus options to the end user.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Biggels wrote:
Regardless, I shouldn't have to modify my ReadyNAS settings. NetGear need to investigate the issue and release a patch. The least they can do is return control of the antivirus options to the end user.
I agree.
It's clear they are looking into the AV issues (there's been one patch pushed already). Likely a replacement for the AV Plus controls is on their "to do" list.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Will they be addressing the disk space warnings as well?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Been 24 hours since I turned off AV
Have recieved no Disc Usage Warnings to date
- Mark as New
- Bookmark
- Subscribe
- Permalink
The disk capacity alerts are false anyways.
I refuse to compromise our infrastructure by turning off the antivirus. Sure hope NetGear comes up with a fix sooner, rather than later.
- Mark as New
- Bookmark
- Subscribe
- Permalink
This fix worked for me. (Disable antivirus, reboot, waited until next day, activated antivirus).
No disc space errors since late evening of 21st Jan.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Wrong - not fixed. had 2 messages had "Less than 20% of volume media's capacity is free" at 01:17 followed by "Less than 5%..." at 01:27 but no messages when shutdown/restarted at 06:00
Firmware;
:6.6.1
Antiviris: Active
"System/Volumes" shows
Data 592.87GB
Snapshots 2.75GB
Free Space 1.23TB
Type RAID 5
- Mark as New
- Bookmark
- Subscribe
- Permalink
Netgear is working on AV fixes. If you leave the current version enabled, it is likely you will see errors.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Here is a work-around before the beta or official firmware, it should fix this issue:
- Turn on SSH service through the Admin Page and SSH into ReadyNAS
- Remove or comment out the lines starting with OnAccessExcludePath in file /etc/clamav/clamd.conf, save it.
- Restart the clamav by running this command: systemctl restart clamav-daemon
Note that this clamd.conf configuration file will be overwritten again if re-enabling Anti-Virus, so above steps need to be re-done after re-enabling AntiVirus.
