× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
Duo V1 Dead
chriscowanuk
Duo V1 Dead
My Duo V1 made a popping sound and went dead. Assume something has blown inside. I can probably cobble together a recovery from USB backup and offsite backup although the latter is out of date. The question I have is can the data from the disks which I assume are fine be recovered?
Message 1 of 9
Accepted Solutions
bedlam1
Prodigy
Re: Duo V1 Dead
No, connect them to your Windows PC either with a Sata cable or a USB drive caddy
Message 4 of 9
All Replies
Guru
Re: Duo V1 Dead
If you were using the default XRAID then R-Linux for Windows should be able to access the data volume from drive 1,
Message 2 of 9
chriscowanuk
Re: Duo V1 Dead
Do I need another Duo V1 chassis to put the disks into?
Message 3 of 9
bedlam1
Prodigy
Re: Duo V1 Dead
Message 4 of 9
chriscowanuk
Re: Duo V1 Dead
I find I have another problem which is I can't get the disks out of the dead Duo V1, because you need power to unlock the disk enclosures!  Oh dear. Any ideas?
Message 5 of 9
bedlam1
Prodigy
Re: Duo V1 Dead
I don't think so, are the levers locked (small tab slider at bottom of each)
See Page 11 HERE
Message 6 of 9
chriscowanuk
Re: Duo V1 Dead
Message 7 of 9
chriscowanuk
Re: Duo V1 Dead
No problem I found a Youtube video that tells you how to do it with a paper clip!  So this particular problem solved.
Message 8 of 9
Guru
Re: Duo V1 Dead
Yes, there are also some theads here on it - for instance here: https://community.netgear.com/t5/ReadyNAS-Hardware-Compatibility/Stuck-Disk-Tray-on-ReadyNAS-Duo/m-p...  In my experience method "B" works best.
I'd like to add that your problem has nothing to do with power.  It was an issue with the older trays.  The newer trays with square release buttons don't have this particular problem.
Message 9 of 9
Top Contributors
Discussion stats
  • 8 replies
  • 3810 views
  • 0 kudos
  • 3 in conversation
Announcements
