- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
How long does it take to expand a volume on a ReadyNAS 104
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi,
I have a ReadyNAS 104 that I had started using with just one disc in it, a WD Red 4TB. However as it was near capacity I got another WD Red 4TB to expand the volume onto.
It did take a while (about 12 hours) for the disc to become ready. Though to expand the volume and use both discs I understand I had to reboot the ReadyNAS. So I have done this, however ever since the display has said "Restarting now. See you soon."
Have been lead to believe this will take a while, though can someone give an idication of how long, as it has now been 48 hours and I am concerened that something is amiss.
Currently I am unable to access the ReadyNAS over the network, obviously I guess as it is still in process of booting, so unable to actually confirm if it is doing anything.
Thanks
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
It seems awfully long to me, and normally RAIDar should be able to see it.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: How long does it take to expand a volume on a ReadyNAS 104
Actually you'll need to have 3x4TB to get more capacity. 2x4TB just gets you redundancy.
What status are you seeing with RAIDar?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Raidar cannot find anything on my network. Though only used that after it went into this boot sequence. As did all previous configuring through the web interface.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Also then is it possible to disable the redundency, I would prefer the space? As I use other things for back up. I really need this more for a networked storage than its actual redundency and can't afford a third drive for a while.
- Mark as New
- Bookmark
- Subscribe
- Permalink
You would need to switch to flexraid, destroy the volume, and then create two new ones (jbod).
One RAID-0 volume is possible, but is a bad idea (if either disk fails you lose all the data).
- Mark as New
- Bookmark
- Subscribe
- Permalink
Any idea though if it should be taking this long to boot back up? 48 hours for a total of 8TB of data (even if that is 4TB redundant) seems an awful long time.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks, did a forced reboot and now it is back up. Currently balancing, and I can see it on the network again.
Though as you said earlier it is redundant and not more space. I may wipe it and set up as Raid 0, I understand the risks with that.
