× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
No Volume Exists, need to bring volume back!
Jamestown
Hi All,
We have a ReadyNAS Pro Business Edition [X-RAID2] running firmware RAIDiator 4.2.22
A drive died in our system and the person who replaced the drive replaced the wrong one. After replacing the wrong one they quickly realized, took out that disk and put it in the correct spot. They did this without letting the drive properly sync before removing. Now ALL our data seems to be lost. When looking at the FrontView GUI it says "No Volume Exists". Can anyone help us recover our data and re-create this volume group? Please??
Output lvscan:
No volume groups found
Output vgscan:
  Reading all physical volumes.  This may take a while...
Output fdisk -l
Found valid GPT with protective MBR; using GPT
Disk /dev/sda: 976773168 sectors, 465G
Logical sector size: 512
Disk identifier (GUID): c47c8e9c-6e8b-4351-8965-e7ba5777fddf
Partition table holds up to 8 entries
First usable sector is 4, last usable sector is 976773164
Number Start (sector) End (sector) Size Code Name
1 4 8388611 4096M 0700 Linux RAID
2 8388612 9437187 512M 0700 Linux RAID
5 9437189 976768064 461G 0700 Linux RAID
Disk /dev/sdb: 976773168 sectors, 465G
Disk identifier (GUID): d25225fd-18d9-4a02-962b-e0f687898f93
Partition table holds up to 128 entries
First usable sector is 34, last usable sector is 976773134
1 64 8388671 4096M 0700
2 8388672 9437247 512M 0700
5 9437256 976768131 461G 0700
Disk /dev/sdc: 976773168 sectors, 465G
Disk identifier (GUID): 7f3265c6-d23f-4867-bfa2-9be425e25185
Disk /dev/sdd: 1953525168 sectors, 931G
Disk identifier (GUID): 8602aecc-33a7-4719-acff-4aa522dfa41c
First usable sector is 34, last usable sector is 1953525134
6 976768136 1953521038 465G 0700
Disk /dev/sde: 1953525168 sectors, 931G
Disk identifier (GUID): e1178127-329f-4f5f-a230-e3c4bd1dd6d7
Disk /dev/sdf: 1953525168 sectors, 931G
Disk identifier (GUID): 88ea026c-96ea-426e-a5eb-743ef66b7ddc
Disk /dev/md0: 4294 MB, 4294955008 bytes
2 heads, 4 sectors/track, 1048573 cylinders
Units = cylinders of 8 * 512 = 4096 bytes
Disk /dev/md0 doesn't contain a valid partition table
Output: cat /proc/mdstat
Personalities : [raid0] [raid1] [raid10] [raid6] [raid5] [raid4]
md3 : active raid5 sdf6[0] sdd6[2]
488374784 blocks super 1.2 level 5, 512k chunk, algorithm 2 [2/2] [UU]
md2 : active raid5 sdf5[0] sda5[5] sdb5[3] sdc5[2] sdd5[1]
1934655488 blocks super 1.2 level 5, 512k chunk, algorithm 2 [5/5] [UUUUU]
md1 : active raid6 sda2[0] sdb2[6] sdf2[4] sde2[8] sdd2[2] sdc2[7]
2096896 blocks super 1.2 level 6, 64k chunk, algorithm 2 [6/6] [UUUUUU]
md0 : active raid1 sdf1[7] sda1[6] sde1[9] sdd1[8] sdc1[11] sdb1[10]
4194292 blocks super 1.2 [6/6] [UUUUUU]
unused devices:
Message 1 of 1
Top Contributors
Discussion stats
  • 0 replies
  • 20638 views
  • 0 kudos
  • 1 in conversation
Announcements
