× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
Please help! Problems with a Netgear Pioneer Pro 6 and a Logitech Transporter after factory reset
gclpc
I have a Pioneer pro 6 with 2 Logictech transporters. Everything was working fine until a recent move. I had 2 hds damaged during the move. I had to replace the hds, and do a factory reset. I reinstalled the data, and now I can listen to radio over the Transporters, but when I try to access the server, the Transporter identifies that it is there, but when I try to access it, the transporter shows an "x" beside the server name. Support at Logictech is less than useless. Any ideas?
Greg
Message 1 of 5
mdgm-ntgr
NETGEAR Employee Retired
Re: Please help! Problems with a Netgear Pioneer Pro 6 and a Logitech Transporter after factory rese
Perhaps you need to install/update an add-on that you were using before the factory reset?
Message 2 of 5
gclpc
Thanks for the reply. Already did that...
Message 3 of 5
mdgm-ntgr
Which firmware are you running?
Which add-on and version?
Message 4 of 5
gclpc
Finally, after hours of screwing around, I deleted the current version of the Logitech Media Server (7,75) and tried 7.8. That didn't work so I deleted it and went back to 7.1. That worked! Does anyone know in which version Netgear took the LMS out of the streaming services tab in frontview, and added it to the add-in page?
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 2223 views
  • 0 kudos
  • 2 in conversation
Announcements
