- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Plex Broken after upgrade to 6.7.3
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi,
i upgraded to 6.7.3 after the update i'v had some issues:
- i am unable to start plex server
- unable to remove plex server
- web interface doesn't always work on windows 10 (ie, firefox, chrome) mac works perfect
does anyone have a fix for this issue?
kr,
Mattias
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
current status:
plex issue solved:
remove plex
dpkg --purge plexmediaserver-ros6-binaries
remove vim
apt-get purge vim
remove vim-runtime
apt-get purge vim-runtime
reinstall vim
apt-get install vim
use gui to reinstall plex and reboot
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Plex Broken after upgrade to 6.7.3
CouchPotatoServer has the same issue 😞
System: Cannot uninstall application CouchPotatoServer.
- Mark as New
- Bookmark
- Subscribe
- Permalink
after some troubleshooting i was able to remove plex using:
now i'm unable to reinstall it error:
Cannot install application plexmediaserver-ros6-binaries.
- Mark as New
- Bookmark
- Subscribe
- Permalink
current status:
plex issue solved:
remove plex
remove vim
apt-get purge vim
remove vim-runtime
reinstall vim
apt-get install vim
- Mark as New
- Bookmark
- Subscribe
- Permalink
I found my apt-update procedures failed because of a failing dependency regarding vim, thus
uninstalling vim and reinstalling is a good way to help with the blocked update packages.
- Mark as New
- Bookmark
- Subscribe
- Permalink
If you install 3rd party packages that can break things, yes. Something else that might have worked could possibly have been to install the updated vim over the top of the already installed one without going and removing it.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yeah, i tried, but the dependency between some of the vim libs will result in a fail to upgrade it. Simply deinstalling vim and vim-tiny and reinstall vim will work as expected and remove the autoupdate blockade.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Supid question maybe but whats VIM?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
@goi wrote:https://manpages.debian.org/jessie/vim-common/vim.1.en.html
Ahh, i'm tired.. ofc... Thanks!
- Mark as New
- Bookmark
- Subscribe
- Permalink
I had a plex startup problem on 6.7.4. it oddly didn't happen until after my 3rd boot (2 6.7.4 hangs by the way so seems worse to me than the prior version). The problem was very mysterious, I think it was related to this vim issue but even after doing these steps and having a good install it still happened. I loaded and exported the contents of the environment file manually from the shell prompt and then invoked the server from the command line. It came up and looked good from the web so I exited, ran systemctl daemon-reload on a whim and then tried to start it again from front view. This time it finally started. Spent 45 minutes dorking around with this and I have no idea what really fixed it.
