- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RN104 - Out of Memory 36c
- Mark as New
- Bookmark
- Subscribe
- Permalink
RN104, did an update to 6.6 and now the system is getting Out of Memeory 36c. I was fianlly able to get it intoread only mode, long enought to grab the logs. Any help would be greatly appreciated.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RN104 - Out of Memory 36c
Hi brianjmc1,
Do you remember what firmware were you upgrading from?
Did you load 6.6.0 or 6.6.1?
How do I send all logs to ReadyNAS Community moderators?
- Mark as New
- Bookmark
- Subscribe
- Permalink
6.6.1 - just sent the logs, i can get it into Read only mode, but freezes in 5-10 minutes...
Thanks for your time,
Brian
- Mark as New
- Bookmark
- Subscribe
- Permalink
Just disabled quotas. We'll see if this makes a difference on your system.
- Mark as New
- Bookmark
- Subscribe
- Permalink
RN104, did an update to 6.6.1 and now the system is getting Out of Memeory 36c. Booting to 99% and " Out of Memeory 36c"
How get data frome RN104?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Don't know if this helps....
Tech finally remoted to my RN104 and turned OFF quotas, rebooted and all is working fine....
Try turning off quotas if you can, might need to put it in one of the other modes...
- Mark as New
- Bookmark
- Subscribe
- Permalink
I cannot see web page of RN104, becouse it`s not boot complete, only 99%...
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Свободно менее 20% от емкости тома media. Производительность тома media снизится, если резервная емкость будет заполнена. NETGEAR рекомендует увеличить емкость тома, чтобы избежать снижения производительности
- Mark as New
- Bookmark
- Subscribe
- Permalink
Том: Заполнение системного тома root составляет 85%. В обычных условиях такое состояние возникать не должно. Свяжитесь с технической поддержкой.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks! Now need to resolve problem
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
You are going to rack your brains on this.....I tried EVERYTHING, nothing worked. Only way it was fixed, a tech from this forum, ask for permission and remoted to the box, he cleared the quotas and rebooted. It was using 4tb and had 4tb free... the tech was mdgm and he was GREAT!!!!
good luck...
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
@alfacom wrote:
but i dont have such Volume
You do have a system volume - usually called the OS partition here. You can't normally see it, but the OS is installed on the disks.
I do suggest using paid netgear support to deal with your out-of-memory issue (and they can also resolve the issue with a full system volume).
If you are running 6.6.1 firmware (and have access to the web ui) then I suggest disabling the antivirus service.
If you can download the log zip file, you can look at the system data usage. Volume.log has a section with a df . -h header. The first few entries (up to and including the tmpfs entries) are used by the system itself, and generally shouldn't be very full - no more than ~20%.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Pools
Pool root:
Device: /dev/md0
Node: 9:0
HostID: 0e34fa56 (native)
UUID: 0bd80197-f7f9-49f1-8c43-80767bda63ce
Mount point: /
Size: 3882076KB (3 GB)
Available: 376788KB (0 GB)
RAID Level: 1
State: redundant
Action: idle
Flags 0xA8
Type: ext4
RAIDs:
md0
Level: 1
Action: idle
Members: 4
Disks:
sdd:
HostID: 0e34fa56
Flags: 0x0
Size: 11721045168 (5589 GB)
Free: 14
Controller 0
Channel: 0
Model: TOSHIBA_HDWE160
Serial: 3661K850F56D
Firmware: FS2A
RPM: 7200
SMART data
Latest Self Test: Passed
sdc:
HostID: 0e34fa56
Flags: 0x0
Free: 14
Controller 0
Channel: 1
Serial: 3664K41XF56D
Firmware: FS2A
RPM: 7200
SMART data
sdb:
HostID: 0e34fa56
Flags: 0x0
Free: 14
Controller 0
Channel: 2
Serial: 3661K84WF56D
Firmware: FS2A
RPM: 7200
SMART data
sda:
HostID: 0e34fa56
Flags: 0x0
Free: 14
Controller 0
Channel: 3
Serial: 3661K851F56D
Firmware: FS2A
RPM: 7200
SMART data
Pool swap:
Device: /dev/md1
Node: 9:1
UUID: d5b50a0c-8ce2-449f-bdb5-eec267d0ad25
Mount point: none
Size: 0KB (0 GB)
Available: 0KB (0 GB)
RAID Level: 6
State: inactive
Action: idle
Flags 0xA8
Type: swap
RAIDs:
md1
Level: 6
Action: idle
Members: 4
Disks:
sdd:
HostID: 0e34fa56
Flags: 0x0
Free: 14
Controller 0
Channel: 0
Firmware: FS2A
RPM: 7200
SMART data
sdc:
HostID: 0e34fa56
Flags: 0x0
Free: 14
Controller 0
Channel: 1
Firmware: FS2A
RPM: 7200
SMART data
sdb:
HostID: 0e34fa56
Flags: 0x0
Free: 14
Controller 0
Channel: 2
Firmware: FS2A
RPM: 7200
SMART data
sda:
HostID: 0e34fa56
Flags: 0x0
Free: 14
Controller 0
Channel: 3
Firmware: FS2A
RPM: 7200
SMART data
- Mark as New
- Bookmark
- Subscribe
- Permalink
May be Netgear must do more usefull updates?
- Mark as New
- Bookmark
- Subscribe
- Permalink
=== df -h ===
Filesystem Size Used Avail Use% Mounted on
udev 10M 4.0K 10M 1% /dev
/dev/md0 4.0G 3.4G 368M 91% /
tmpfs 249M 0 249M 0% /dev/shm
tmpfs 249M 13M 236M 6% /run
tmpfs 125M 2.0M 123M 2% /run/lock
tmpfs 249M 0 249M 0% /sys/fs/cgroup
/dev/md127 17T 7.4T 9.1T 45% /data
/dev/md127 17T 7.4T 9.1T 45% /apps
/dev/md127 17T 7.4T 9.1T 45% /home
/dev/md127 17T 7.4T 9.1T 45% /run/nfs4/data/base
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
There is an option in ReadyNASOS 6.7.0-T169 (Beta 2) to disable quotas at the volume level.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Is this post fixed?
I was always told that :
is a dangerous thing, /dev/md0 should be no more than like 40% .. When it reaches 100 it will die again
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ah, the problem with having different issues for different users discussed in the one thread. That certainly needs fixing.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Need to do anything after intall and reboot?
Now i`m loadded firmware, reboot and nothing... RN104 not working
- Mark as New
- Bookmark
- Subscribe
- Permalink
