× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
RN104 adding third drive takes very long
RPG_228
Hello everyone,
I've got a readynas 104 with 2 x 2TB drives (XRAID). They are 95% full of data so i added a third 2 TB drive.
Since i added the third drive the drive i can't view the admin page of the NAS anymore.
It's been 48 hours since i added the drive and the volume still hasn't expanded.
Is it normal that it takes so long?
I can still use the NAS as normal, all my data is intact and all the sevices are running (FTP,plex, etc)
the blue drivenumber on the NAS is blinking. So i assumed it was busy with syncing the data.
The display shows: Readynas and its IP number.
I thougt about resetting the NAS but i'm a bit afraid of losing my data.
Message 1 of 11
Accepted Solutions
mdgm-ntgr
NETGEAR Employee Retired
Re: RN104 adding third drive takes very long
Thanks for the logs.
Your data volume is pretty much 100% full.
This is not good.
We recommend keeping volume usage around the 80-85% mark.
Do you have a backup? You should backup your data if you have not already as the next step.
It looks like your new disk has been added to the data volume array, but not to the OS or swap arrays. Expansion has not occurred.
You could try rebooting the NAS via RAIDar and see what happens.
Message 9 of 11
All Replies
Guru
What status is RAIDar giving you?
If you don't have a backup, it would be a good idea to make one.
Message 2 of 11
RPG_228
I didn't of checking RAIDar before.
RAIDar shows 2 working drives and 1 with a syncing symbol.
I tried pasting a image of the raidar view in this message.
I hope it shows up.
Message 3 of 11
Guru
If you hover your mouse over the syncing drive, it should provide some completion status info.
Message 4 of 11
RPG_228
i tried doing that.
But it just shows CHANNEL 3 followed by the drive name/type and temperature.
Basicly the same info as the 2 allready installed drives.
No info on the completion status.
If it helps i can download the logs.
Message 5 of 11
mdgm-ntgr
The logs could be useful. Please download them using RAIDar then send them in (see the Sending Logs link in my sig).
Message 6 of 11
mdgm-ntgr
The logs were not attached to your email.
Message 7 of 11
RPG_228
Oops sorry,
I'll send them again.
Message 8 of 11
mdgm-ntgr
This is not good.
Message 9 of 11
RPG_228
i didn't know about not exeding the 85% mark.
I will keep that in mind in the future
So, i rebooted the NAS via Raidar and it rebooted like normal.
Even al 3 drives showed as normal and running in both RAIDar and the admin view, only the total volume didn't expand.
Then i shut down the device removed the 3rd (new) disc and started it up again.
When it was finished booting the display warned about degraded data and RAIDar gave a warning about the RAID5 being non redundant.
I decided to shut the NAS down again and put the drive back in.
When i booted up again the drive starting syncing (message in display)
RAIDar also displays the volume data is syncing (3,4% complete)
I guess this is a good sign?
Message 10 of 11
RPG_228
When i woke up this morning the disk was finished syncing and the data volume was expanded.
everything is running as normal and the data volume is currently about 50% full.
Thanks for the help
Message 11 of 11
Top Contributors
Discussion stats
  • 10 replies
  • 3030 views
  • 0 kudos
  • 3 in conversation
Announcements
