- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RN516 Vertical Expansion for volumes over 16 TB
- Mark as New
- Bookmark
- Subscribe
- Permalink
Does the no autoexpand with volumes above 16TB limitation still exist? Is there any explanation to why this limitation exists?
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Backed up NAS and did the factory reset, which fixed the expansion problem as it should have. I checked the available apps page while the Nas was resyncing and it was populated, but this morning, the available apps page is empty. I manaully loaded PLEX and it installed properly and the icon is present on installed apps page. The available apps page is still empty?
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RN516 Vertical Expansion for volumes over 16 TB
That limitation has never affected our OS6 x86_64 products such as the RN516.
It was a limitation of EXT4 which we used for the data volume on legacy systems.
There were also some limitations on OS6 ARM (even though we use BTRFS for the data volume) on firmware prior to 6.4.0 due to our ARM products being 32-bit.
- Mark as New
- Bookmark
- Subscribe
- Permalink
mdgm,
Thanks for the info. Do you have any suggestions to fix my non-expansion after reboot problem then? I know I could spend a few days transferring all the Shares off the NAS and do a factory reset, but I'd rather not if there is an alternative I can try...
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Started with 6 x 3TB drives, 1 volume using xraid-2. Swapped out the 3TB drives with 4TB drives, one at a time, letting the NAS resync after each drive swap. After all 6 3TB drives had been exchanged with 4TB Drives, I rebooted the NAS to allow for expansion. Still showing the same Volume size (10.9TB) as it did with the 3TB Drives instead of 14.53TB which my other NAS shows with the exact same drives with xraid-2... Both NASs are RN51600s... OS 6.5.1 on both...
- Mark as New
- Bookmark
- Subscribe
- Permalink
6x3TB should show ~13.6 TB of storage with single redundancy XRAID. 10.9 is what you'd see with dual redundancy/RAID-6 (and 14.53 is what you'd see with dual redundancy 6x4TB).
So it actually should have expanded when you added the fourth 4 TB drive. The XRAID control on the volume tab has a green stripe?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yessir, the X-RAID has a green stripe indicating it is active....
I just tried rebooting again, still no expansion...
- Mark as New
- Bookmark
- Subscribe
- Permalink
Please send me your logs (see the Sending Logs link in my sig).
- Mark as New
- Bookmark
- Subscribe
- Permalink
logs sent...
- Mark as New
- Bookmark
- Subscribe
- Permalink
The volume should automatically expand.
Do you have an up to date backup of your data?
- Mark as New
- Bookmark
- Subscribe
- Permalink
no, I would have to create one... Sounds like you are suggesting backup and factory reset?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Would an OS reinstall be worth trying?
- Mark as New
- Bookmark
- Subscribe
- Permalink
mdgm,
Full backup of all shares and a full configuration backup should be fininshed later todsy or tomorrow...
- Mark as New
- Bookmark
- Subscribe
- Permalink
An OS Re-install wouldn't fix this, but once you have your backup I wouldn't see any harm in trying that.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
UPDATE : problem solved with PLEX Apps...
