× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
RN516 "mount_block_root + 1f1" after os 6.7.3 update
adinx
Hi there,
I tried updating from 6.7.2 to 6.7.3 today and it has killed my Readynas.
Now I have the error mount_block_root +1f1 whenever it boots.
I have tried to do the usb recovery but it is not working. It gets to the stage where it says booting from external usb and then it goes to the error message. I have also tried pressing the reset button at the back to get the boot menu but it also does not work.
Please I would really appreciate any help as I am panicking.
Model: RN51600|ReadyNAS 516 6-Bay
Message 1 of 13
Accepted Solutions
mdgm-ntgr
NETGEAR Employee Retired
Re: RN516 "mount_block_root + 1f1" after os 6.7.3 update
If you have updated to 6.7.3 and ran into this issue please try USB Boot Recovery with ReadyNAS OS 6.7.4 which is now available!
If you have not yet upgraded please upgrade to 6.7.4 rather than 6.7.3. If your system has already been fixed I would still suggest updating to 6.7.4 the normal way using the web admin GUI.
If you can't do USB Boot Recovery despite trying multiple different USB keys and following the directions you'll need to contact support.
Message 13 of 13
All Replies
mdgm-ntgr
This error message would suggest that USB Boot Recovery is the right way forward. Have you tried other USB keys?
Which version of Windows are you using to create the USB Boot Recovery key?
Message 2 of 13
Marky187
This just happened to me last night aswell.
mount_block_root
+1f1
After trying to do a firmware update.
Message 3 of 13
adinx
Hello mdgm,
I'm using Windows 10. I followed the instructions. Am I supposed to use any other version?
Please advise.
Message 4 of 13
adinx
Sorry, Windows 8.
Message 5 of 13
Tintin75
Bonjour,
Après la mise à jour du firmware, 6.7.3 j'ai un message à l'écran :
mount_block_root
+1f1
Modèle du NAS RN31400
Le serveur n'est pas visible sur le réseau local, impossible de faire quoi que ce soit.
Fichier clients sur le serveur, que dois-je faire pour annuler la mise à jour.
Merci d'avance.
Message 6 of 13
mdgm-ntgr
adinx have you tried multiple USB keys? So it won't boot off the USB? I've sent you a PM.
Tintin75, have you tried USB Boot Recovery?
Message 7 of 13
Tintin75
Je vous ai répondu en MP
Message 8 of 13
nsne
Virtuoso
Can @adinx or @Tintin75 explain how this was solved? I have the same problem but am not having any success.
Message 9 of 13
Tintin75
Changement du NAS, moyennant finance. Impossible à booter, verrouiller de chez verrouiller. Cause mise à jour du firware.
Message 10 of 13
adinx
I tried everything possible but couldn't get it to work. Got really frustrated. Did an RMA and they are sending the replacement.
Message 11 of 13
mdgm-ntgr
Message 12 of 13
mdgm-ntgr
Message 13 of 13
Top Contributors
Discussion stats
  • 12 replies
  • 10725 views
  • 4 kudos
  • 5 in conversation
Announcements
