- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
ReadyNAS 104 not shutting down
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have a problem where I have a power schedule configured on my NAS. But, it seems to hang on shutdown. The only way to resolve the issue is to power cycle it.
This is happening to the two ReadyNAS 104 units I have. It seems to happen on firmware versions 6.2.4 and the newer 6.2.5
It is a pain, since my units are in my attic, and means I have to go up to power cycle them. My older ReadyNAS NV+ doesn't suffer from this issue.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: ReadyNAS 104 not shutting down
If you shutdown (or restart) from the web ui, do you have the same issue?
- Mark as New
- Bookmark
- Subscribe
- Permalink
It seems to restart and shutdown from the web GUI just fine.
So, the issue appears to only happen when it is set to a scheduled shutdown.
- Mark as New
- Bookmark
- Subscribe
- Permalink
So you didn't see this issue till you updated to 6.2.4 (or newer)?
What apps and services are you running?
Can you send me your logs (see the Sending Logs link in my sig)?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Correct. Only seen since 6.2.4 and in 6.2.5.
No apps running at all.
I will send on logs now.
- Mark as New
- Bookmark
- Subscribe
- Permalink
You have both MySQL and anti-virus running on this system. I would suggest not having both of these running at the same time on a 100 series unit.
Since MySQL wouldn't be installed by default it seems you had some apps on this system at some point.
I see you have disk spin-down enabled. Does the problem still occur if you disable disk spin-down.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ok, I knew about the anti-virus, but didn't know MySQL was there. It's not listed in the "running apps", nor the installed apps. I will have to look at how to remove it.
I can certainly disable the disk spin-down. I thought it would help conserve disk usage and power.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I've disabled spin-down now. So I will see tonight does it shutdown on schedule.
Still no idea how to disable/uninstall MySQL, since it's not listed as installed nor running.
- Mark as New
- Bookmark
- Subscribe
- Permalink
No improvement. The system was hung again this morning.
Is there a way to uninstall/disable the MySQL? I guess the problem is that it is not listed in the "Running Apps" nor the "installed apps" so I have no direct way to uninstall it.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ok, still no improvement. Both my ReadyNAS 104 still hang on shutdown.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have this same problem but only once I updated the firmware to 6.4.0. The nas will sit with the power button flashing but not shutdown. The only way to get the nas to shutdown is to remove power from the unit. The power button does not do anything. When I was on 6.2.5 the system would shutdown at 6am after running some scheduled backups. Then start back up at 10am when I needed the nas. I am not running antivirus or any apps. I do have the drives spin down after 10 minutes of inactivity.
- Mark as New
- Bookmark
- Subscribe
- Permalink
The same problem here. Is there a solution out yet?
Kind Regards
Thomas
- Mark as New
- Bookmark
- Subscribe
- Permalink
Try setting th MTU to the default value of 1500 - this solved the same issue for me.
- Mark as New
- Bookmark
- Subscribe
- Permalink
MTU has always been default at 1500.
Latest software update applied and it is a little better. It now works sometimes, but not others.
Very frustrating, and has made me select an alternate NAS provider for the latest one I bought.
