× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
ReadyNAS 3100 - HDD more than 3Tb compatibility?
dat4wd
Is it possible to use ReadyNAS 3100 with HDDs 4-6Tb? I read HWCL, but....
Message 1 of 7
mdgm-ntgr
NETGEAR Employee Retired
Re: ReadyNAS 3100 - HDD more than 3Tb compatibility?
Should be possible, but if you run into issues using disks outside the compatibility list support may be refused.
Message 2 of 7
Dinkum
Almost all of the 3TB drives listed have disappered from the market. What other drives do Netgear recommend?
Message 3 of 7
Guru
Netgear doesn't recommend stuff off the HCL.  But it's clear they've neglected it also.
I'd recommend WDC Red (WD30EFRX) or WDC Red Pro (WD3001FFSX).  If you are a Seagate person, then their equivalent NAS drive (ST3000VN000).
Enterprise drives will work too, though they cost more.
I don't recommend buying desktop drives for your NAS - the NAS purposed drives above are better choices.
Note I don't work for Netgear.
Message 4 of 7
Dinkum
Thanks Stephen.
I am happy to use enterprise drives but I am really concerned regarding the expressed statement from Netgear that you will NOT get support if things go haywire.
Some how, I dont' think the WDC Black drives will do a lesser job that the listed ones.
Message 5 of 7
Guru
Perhaps not, but WDC's data sheet says
WD Black PC Hard Drives are tested and recommended for use in consumer-type RAID applications (RAID 0 and RAID 1).* * Business Critical RAID Environments
– WD Black PC Hard Drives are not recommended for and are not warranted for use in RAID environments utilizing Enterprise HBAs and/or expanders and in multi-bay chassis, as they are not designed for, nor tested in, these specific types of RAID applications.
In other words, RAID-0, RAID-1 are ok, RAID-5, RAID-6, RAID-10 are not.
I agree it is a problem.  In my opinion they should not deny support to anyone using NAS or enterprise drives.
Message 6 of 7
Dinkum
Thanks Stephen. I shall look into the WDC Red NAS range.
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 2180 views
  • 0 kudos
  • 4 in conversation
Announcements
